2017EX_imp
Ok folks, first I am going to say up front, I am no Lithium Ion battery expert. So, I am going to pass on my research and observations on the subject, and everyone can draw their own conclusions as well as chime in with additional info and/or experiences with this type battery.
I had contemplated replacing the tried and true stock Yuasa battery with one of the new lithium ion batteries when I noted the tremendous difference in CCA ( cold cranking amps ) between Lead Acid ( LA ) and Lithium Ion ( LI ) batteries. Just as an example a Yuasa LA battery might be 65 CCA, whereas the comparable size LI battery might be 150 CCA. Naturally this started my research and it produced some unexpected results.
In reading some of the reviews on various batteries there were some incidences of the battery causing a fire under the seat. Were those incidents the result of bad wiring on the bike ( voltage regulator ), improper charging, improper installation, who knows? LI batteries have a series of cells inside the case. If charging is initiated with one or more cells at a higher charge than the rest, then that cell or cells can be overcharged before the other cells in the battery catch up and reach full charge. This problem can be managed with a BMS ( battery management system ) built into the battery that balances the cells and protects against under and overcharging. Not all LI batteries have BMS. Here is a link to a YouTube video that does a pretty good job of explaining the situation:
Some LI batteries I looked at said that regular LA chargers and trickle/maintainer chargers could be used with their batteries. More often than not however, the message was to use a dedicated charger like the Shorai mentioned in the YouTube video, or a charger/maintainer specifically made for use with LI batteries.
Apparently numerous LI batteries are made by the same parent company, Skybridge, WPS, WPS Fire Power, Shido and Deltran to name a few. This was speculated in the YouTube video linked below, but I could not find any supporting documentation. The video mentions that the WPS battery has BMS, but I did not find that feature in the batteries specs or description. What it does have is a push button LED charge level indicator.
Among its other quirks, I discovered that LI batteries tolerate heat and vibration well, but cold puts them to sleep. The LI solution to cold, is to turn the headlight on for 1 minute or so, then turn it off. This wakes the battery up, and starting can then be accomplished. From what I saw, a "good" LI battery will be significantly more expensive than a comparable quality LA battery.
Here is my take on the situation, and what I have decided for myself: The LI battery's main claims to fame seem to be lighter weight, and more cranking amps. While those parameters might be important on a race bike, or a custom bike where battery space is at a premium, they make little to no difference for me. The Yuasa battery is a quality battery, with a proven track record, and as with most of us long time riders, everyone knows what to expect with a LA batteries and how to properly maintain them. I will stay with what I know and am comfortable with for the time being. Perhaps at some time in the future when LI batteries have a more established track record, along with the refinements that come with time, I might consider it.
IF I were to go with a LI battery today I would:
Look at Shorai Lightweight Lithium Batteries and Chargers - Experience The Future of Power or Antigravity ATZ10-RS Lithium Motorsports Battery
Both of these batteries have cell balancing, and both have BMS systems. I would not even consider a LI battery that did not have BMS with cell balancing.
Look at Antigravity first because it is more upgraded tech than the older tech Shorai. The Antigravirty also has a "restart" feature explained in the video, and a remote restart key fob will be available for it soon. Down side, is it is pricey. In the case of the Shorai, I would DEFINITELY buy and use ONLY the dedicated charger. Although older tech, Shorai has a good track record. In the case of the Antigravity, or any other LI battery other than Shorai, I would DEFINITELY buy and use ONLY a charger/trickle/maintainer specifically made for LI batteries.
Like I said, I am no expert so feel free to express any difference of opinion. As with many other things, this is a different strokes for different folks thing. In any case I hope the info is useful. :biker:
come on the market, then maybe.
