rdprdp01
Administrator
In my long riding career, my battery maintenance has been limited to purchasing very good batteries, keeping them clean, and replacing them before they actually failed. It has worked for me so far, because I have never had a battery issue.
Recently, I replaced the battery in my CB1100 with my first ever motorcycle lithium battery. There seems to be reasonable consensus that lithium is preferred over lead-acid for the following reasons:
Higher energy density: More power with less weight, improving your bike’s overall performance.
Longer lifespan: When properly maintained, a lithium battery can last two to three times longer than a lead-acid motorcycle battery.
Faster charging: Lithium batteries charge much faster, reducing downtime between rides.
Low self-discharge: They retain their charge for longer when not in use, making them great for seasonal riders.
For more details, check out the folllowing link:
Lithium Motorcycle Batteries: Myths VS Realities - Updated
So with the upgrade, I also felt the need to up my game on the battery maintenance. To that end, I installed a smart charger to help me realize the benefits listed above. Consensus on smart charges is far less universal, but the most common theme follows:
“Invest in a smart charger equipped with automatic voltage detection capabilities. These chargers can identify the battery’s voltage and adjust the charging parameters accordingly, eliminating the risk of overcharging or undercharging and optimizing charging efficiency.”
See link for more details:
Lithium Motorcycle Battery Charging: Tips and Insights
I purchased a Duraboost smart charger:
Duraboost Lead / Lithium Battery Smart Charger - Cycle Gear
The installation of my smart charger was straightforward and took about 15 minutes. Pictures follow.
What I plan to do, subject to the validation of the Forum’s Members, is to plug in the smart charger after every ride while I clean the bike, allowing it to charge for an hour or so. I am not inclined to leave it plugged in unattended.
I welcome your comments and thanks for sharing the insights and experiences. David
