Leather luggage for CB
Those brown bags in the UK look hideous as does the seat. That's like those french guys who come over here as tourists wearing those flood pants. With the proper brackets on the side so the bags cover the shock, a good would look ok. Must have had one too many pints over there in the UK. Krikey!
If tan leather is good enough for a white Rolls Royce, it's good enough for my CB.
John
Not surprisingly, taste varies greatly. I think the brown seat on the white CB looks fantastic. Very classic looking. I don't care for the angle the rider has his/her bag at but that's a different story. And, personally, if I went with the brown saddle on the white bike, I'd probably go with a darker, richer brown. Still, I think that one looks sweet.
I received my Degner leather saddlebag with the turn signal cutout and am pretty happy with how it looks. It was a little smaller than my cardboard mock up and the from side slants at a greater angle than the CB's shock, but it gives a streamlined appearance.
I comes with two leather straps to mount to the top of the bag and has two rings on the lower back side to lash the bag to the saddlebag support. I used just one of the straps by utilizing one of the bungee pegs on the grab handle. It does block the grab handle, so I have to grab the other side or the footer bracket to hoist it on the center stand. Also, the lashing straps on the back are a few inches below the bottom of the saddlebag support bracket, so I will need to play with that to fine tune my tie down since I want to figure out a relatively easy way to remove and install the bag.
The quality of the bag is very nice. Given that it wasn't made to fit on this bike, I am happy with the fit.
Now, to get my K&H saddle with matching white stitching.
[url=http://s960.photobucket.com/user/Pflugerville_Bike_Guy/media/20141127_162312_zps82925221.jpg.html]
They look real nice to me!
I liked your cardboard cutout trial. Real good idea for checking fit.
Kijima support. I am pretty sure I left that info out. Webike sells single pieces so you don't have to buy what you don't need. It was around 4000 yen or $35. I bought the bag, support, a fork brace, and a motorcycle cover (cheapest item I could find to get me over the free shipping minimum ) all for around $450. I feel like I got a good amount of stuff for my money.
My K&H seat, sadly, was quite a bit more. I can't imagine I could afford to buy all this were the exchange rate not so favorable right now. I think once I get it, I will be happy I splurged and went with the K&H. It should be a perfect match to the saddlebag and everyone who has ordered one raves about the craftsmanship. The CB is a premium motorcycle and deserves premium accessories.
I wanted to post an update to my installation of the saddlebag. I wasn't totally happy with how it fit. You will see in the photo below a couple inch gap below the turn signal which looked a little sloppy. Also, the back side has d-rings riveted to the bottom corners and a couple of lashing straps are provided. With my saddle back support bracket, those d-rings were about 4 inches below the bracket, so the bag still wanted to sling off to the side and bounce around. Here's how it looked before:
First thing I did was move the front mount that uses the bungee peg from the upper slot in the leather tab to the lower slot. The leather strap I was using on the rear set of mounting slots was too thick to pass it out from the bottom slot and back in through the top slot, so I had to run it up over the top of the leather tab. That and having a buckle and wide spacing on the buckle holes kept me from getting a nice tight draw on the strap. I substituted a nylon strap instead.
[url=http://s960.photobucket.com/user/Pflugerville_Bike_Guy/media/20141227_212219_zps3ab5a475.jpg.html]
Next, I had to do something about securing the back side of the bag to the support bracket. The rear of the bag is reinforced with a thick plastic sheet, so I originally planned to drill holes and bolt some sort of homemade bracket around the supports. I stopped in to a Northern Tool store and found a nifty rivet gun designed for threaded rivets. It's just a steel threaded plug and the run has a threaded tip that you thread the plug onto and insert it into the hole and a squeeze of the gun mushrooms the plug to stay in the hole. Then, for a bracket, I had some little J bend brackets made for attaching bungee to a bicycle. They fit the support bracket perfectly, so I installed a pair and they fit beautifully:
[url=http://s960.photobucket.com/user/Pflugerville_Bike_Guy/media/20141227_212120_zpsd983420c.jpg.html]
The result, a tightly mounted bag that hugs the turn signal as it was intended:
[url=http://s960.photobucket.com/user/Pflugerville_Bike_Guy/media/20141227_212021_zps1a18deb2.jpg.html]
Nice Job! That came out awesome!
I put TourMaster bags on mine, but they aren't leather. They fit really nice and have lots of storage for under $100. They come with rain covers that encase the entire bag. I didn't need any brackets and they don't go near the wheel at all. The way they are attached, they don't allow the bags to push in towards the tire.
I found this:
DEGNER : Leather Saddle Bag [SB-43IN]
Same brand as what Mr. T sells, but made to clear the turn signal so no need to relocate them. This may be on my 2nd round of mods after I order my saddle.
I think the brown would look sharp against the red if you can get a match with the saddle. If you go Corbin, ask them to send you material samples before ordering.
I really like the idea of this bag with a cutout relief for the turn signal. Using the basic dimensions and drawing it out to the best of my ability, I made a cardboard template to see how it might fit on the CB.
This may work well on this bike. The webike site shows it on a Sportster. It would be neat to come up with a bracket that integrates with the saddlebag such that it and the bag can easily mount to the bungee peg bolt holes so when the bag is removed, none of the saddlebag support bracket remains. I also wonder if a local saddle maker might be able to make a bag to more exacting specifications and precise fit with no interference. That might be expensive, though. Anyway, here are some photos to illustrate where I am going with this:
[url=http://s960.photobucket.com/user/Pflugerville_Bike_Guy/media/20141101_105725_zps46c9d513.jpg.html]
Hi
I assume your Kijima bracket isnt removable....do you have a picture of the entire bike without the bag and just the bracket?
thx
also interesting from Degner
I found this:
Hi
thx
Hi
thx
The bracket isn't removed via a quick release mechanism, but it's only held on with 2 bolts which is what holds the passenger grab handle. The bracket slips in between the grab handle and sub-frame.
It's much easier to remove the bracket from the bike than to remove the bag from the bike. If I get motivated to redesign how the bag mounts, I'll get a pic of just the bracket on the bike. Like I mentioned in my earlier post, I'd like to be able to more easily remove the bag and bracket together.
