Papa Weeley_imp
Is anyone else having a problem with their tires losing air? Mine lose about 2-3 lbs. per month. Luckily I check them fairly often, but this seems like a lot of loss for that short amount of time. And it's both the front and rear at an even rate, not just one, so it's not like there's a leak in just one of them.
Just curious if that's the "norm" for these cast wheels?!
. Once a week, or two at a stretch, is good for tyre checks. Get your own gauge. Don't need a digital, just a good quality stick gauge to back up the service station's gauge. If you get your own then look for one with the range approximately 5 - 50psi. They are generally most accurate in the middle of the gauge range.
