syncronizator_imp said:
bioman_imp said:
Interesting. Below is a picture of the screen of my bike taken just after turning the ignition key. You can vaguely see the same hidden icons that you mentioned in your first post.
You can also see that the 'heated grips'-icon is very much on during this split second, but it is NOT on when I have my heated grips on. Perhaps the installer didn't connect the grips properly?
Bioman , do You have OEM heated grips ?
I have OEM one's...and will search for the manual ...
To be honest, I don't know. I bought the bike last year, secondhand from a dealer, with the grips already installed.
I doubt they are OEM. They work very well but I find the on/off button a bit cheap-ish. I think (can check the bike later) there are 5 strengths in total: green, blue, yellow, orange, red, all visible by a corresponding coloured LED that lights up at the button.
Again: they work VERY well but my main complaint is that I often involuntary touch the button when I operate the turn signal button.A few minutes later I get very warm hands and only then realise that I had put the heated grips on. :-/
Anyway, I don't miss the light in de main display, as I can see the little coloured LED on the grip to know it is on.
