The ferret_imp said:
Unless you are high in the rev range and low in the transmission, there isn't a whole lot of compression braking on the CB, but it won't hurt it a bit.
I think books like Code's TOTW, and some of Ulva's advice is geared more toward racers and the spirited road riders that ride specific roads over and over, than the casual street rider. There are differeing techniques for a racer coming into the corner at the end of a long straight on a race track and a casual rider coming to a curve at the end of a long straight on the street, particularly if he is unfamiliar with that road. After the first lap the racer knows what to expect at the end of the straight next lap around, and if there is something unexpected there is a marshall there with a flag to warn him. SO he can come in boiling in 6 th, pull in the clutch , jam down 4 gears and exit in second, because that is the most efficient way thru that turn for the racer. For the street rider he must be more cautious, not knowing what is around the corner, so a series of downshifts may be in order, because he may be able to take that turn in fourth, but he may want to take it in third, or second, depending on what he finds when he gets there and looks through it.
I have turns I know I want to take in 3rd, one I know I want to take in second, and in those cases I will pull in the clutch and make multiple downshifts at once before letting out the clutch in the correct gear. But on unfamiliar turns, I am going to approach it more cautiously, one gear at a time until I decide which gear is the right gear for the situation as it unfolds in front of me.
Racers have the benefit of repeated practice to find shift points, brake points, tip in points, best line, maximum and minimum speed, and those points are learned over many laps. We don't always have that benefit on the street.
All exactly correct.
Now, in Code's first book, since it was mentioned, IIRC he says the brakes are for slowing the bike and the engine is for accelerating.
Code used to race two-stroke bikes and in those days that wasn't even a suggestion, there was very little engine-braking from the 2-strokes.
These days, and with any four-stroke, engine braking is an absolutely critical element of riding. It can be varied by adjustments in the ECU with modern bikes, and even from one sector to another on a racetrack based on GPS or transponder position, as can engine power delivery.
If you ride in high gears, as The Ferret stated, not much engine braking there. Keep the RPM above 5K, there's ample such available.
Anyway, what he also stated about multiple downshifts is what I was discussing in my earlier post.
I learned all that stuff dirt riding which I am sure he did as well. You can either roll a bit or let the clutch out a few times and tap down if you forget to downshift whilst stopping.
I just want to point out that this is a dirt-riding technique, you could do this whilst dirt-riding, no worries, because even though, let's say, you downshifted from 6th to 3rd and were not quite precise in coming back out with the clutch, the rear tire will skid a bit whilst entering the turn, which is expected as a possibility and actually can help with corner entry. Then the throttle would be immediately picked up and perhaps the wheel spun up under power to continue the turn.
This would NEVER be done on a road race track. We always shift discretely into each gear to ensure RPM matching and maximum control. A mismatch at high engine speed and vehicle speed on pavement is very serious, either a blown engine, high-side or some kind of problem is going to ensue.
We have reference points for downshifting and you cannot really miss those when blazing down the front or back straight at 140 mph. They could be cones, or a mark on the pavement, or some other thing.
Every track day sets the cones differently so I usually use pavement marks but those change too.
