Ridem32_imp
The front sprocket on both the 13 & 14 models is 18 teeth the rear on the 13 is 39 teeth the 14 rear is 40 teeth
The ground clearance on the 13 & 14 standard is 4.9 inches. The deluxe is 5.3 inches
Engine dry weight 13 models 191.6 pounds
14 engine dry weight (6 speed) 192.9 That's 1.3 pounds different for the 6th gear
Timing on the 13 models 8 BTDC 14 models 10 BTDC
13 models have 3 piston front brake caliper pistons.
14 models have 2 ( larger) front brake caliper pistons.
The 13 model front center caliper piston is combined with the rear brake on the ABS model.
The 14 model is not combined ABS
The 14 deluxe has .7 tenths bigger fuel tank, gear indicator and fuel mpg display. That's the main minor difference I can find between the 13 & 14 models. All info is from honda service manual for the 13 & 14 models.
