Fitting Yoshimura Centre Stand Stopper
Hi all,
Eventually, after a three month wait, my Yoshimura Centre Stand Stopper has arrived... But with no fitting instructions, fitting kit, etc.
Has anyone fitted fitted one on here?
It's a fairly hefty bracket and it looks to me like it fits over the top of the centre stand lugs on the frame.
I'm thinking I should remove the CS spindle, slip the CS stopper over the frame lugs for the CS and then re-fit the CS spindle.
I'm going to have a go at it on Wednesday, but if anyone's got any advice, it would be great to hear it... Or put me right if I'm off the mark with the fitting.
Many thanks
Kev
Installing this is a bit of a pain. Hopefully you have the hardware as some of it needs to be swapped from stock. Here are the installation instructions.
Thanks for that veech. I'll have a look and see if it helps any, but mine is for a 2014 model and its a different looking beast. Much more stout. I'll take a pic and post it up, see if anyone has any ideas. Thanks tho, I'll see if the principal looks the same on the one you've posted the link too. Actually, they may have the instructions for the 2014. Where did you find the pdf?
Thanks
Kev
You're very welcome, and yes the instructions are on the Yoshi website. If you need any parts at all call Yoshi USA (contact is also on the website.) They are very helpful and with the instruction sheet you can find any part number and order directly from them. I had to get a new clamp and they sent one right out.
