Delkavic exhaust and your center stand....
I have the 14" oval Delkavic slip on on my bike. The pipe extender has a stop for the center stand, the extender pipe I mounted eventually loosened and turned and let the center stand come up higher and higher until the chain was rubbing it! Luckily I noticed it before any damage was caused. I think what happened is that when I originally mounted the extender pipe I had pushed it on to the header pipe too far, the clamp was passed the thicker ring on stock header not letting it tighten as it should. Lesson learned. Check those center stand stops if you have this set up......
GaryMNM_imp said:
Yup, mine needed it as well. Pic's added for a visual.
Thanks for the heads up MMC!
Sent from me
