I think you mean the rear sprocket. The counter sprocket is on the countershaft and is the front or drive sprocket. Going up a tooth will raise the gearing.The ferret_imp said:If you think the gears are too tall, many on the forum who like a more spirited ride go up a tooth on the counter sprocket. More acceration, higher cruising rpms, less top speed.
Be sure and check your tire pressures if you haven't already 36F 42 R
