Fenianbastard_imp
I followed the instructions on the first page and it was easy. Be sure to put everything back together the way you took it apart or you will end up with just two gears like me!. It took two minutes to correct it. The fluid was much darker than the brake fluid which I did at the same time. My rear brake reservoir had clear crystals which I had never seen in brake fluid before.
