SUPERCRUZ_imp
Running like a top
Anybody changed out there clutch fluid yet? i would think this fluid needs to be changed with the same frequency as the brake fluid if not more often. I believe the hydraulic clutch uses the same DOT4 brake fluid as the brakes. Is there access to a bleed valve to bleed the system. Those with service manuals, please chime in.
