No point blindly throwing a pile of parts at the bike needlessly.
Until you do the math- the stock tb may be perfectly fine, same goes for the valve sizes, head port flow, etc.
You could easily loose power by making parts too big by loosing velocity, changing pulse resonance, etc.
No way would I ever consider ‘converting’ to another bikes TB. You’ll never get it to work correctly the same as stock.
What I would do- *IF* the tb ever became the bottleneck is start with old hot rod tricks-like permanently securing the butterfly screw threads and then grinding down the screw heads, thin the shafts, possibly remove one side of the shafts.
Heck, if you want to go crazy you can have a machine shop remove the stock plates, bore the housings to a little larger ID, fabricate new larger plates.
That would give you ‘bigger tb’ with no conversion mounting / control hassles.
As already said- there is a lot to do before you get crazy.
Bigger pistons and upping the CR certainly would make power with relatively easy work. Like the cams, you would need to have them custom made.
Would be next on my list if I ever want more after the cams are done. Probably will never do them though as I have never seen an aftermarket piston last like an untouched factory engine- doesn’t matter if on a bike or a car.
Why don’t you start by adding 2-3 teeth to the rear sprocket or dropping the front a tooth?
misterprofessionality_imp said:
just curious a bit....but i'm wondering, why not buy something like a ZRX1200 or the like if you really want a modern inline-4 with that kind of power? is it just about the aesthetics of the CB11?
I own a ZRX1200. Has a full pipe and jet kit. Makes a ton of power compared to the CB.
Yes- I like the CB look and vibe.
If you go on the ZRX forum you will still find guys hot rodding- bigger pistons, bigger carbs, cams, etc.
