davedep_imp
First service completed
Need some info and help in the right direction. Brought the bike out to clean up to start the season. Went to start it and turned key, both speedo and tach cycled up and the oil, temp and neutral light came on, but no sound of the fuel pump and my aftermarket gear indicator counter did not cycle. Clutch handle pulled in, starter pushed, and.....nothing. I did notice lights were on front, rear, turn sigs work, high beam and horn work. I did notice when starter is pushed headlight does go off.
Thought it might be bad battery( 2013 std with original battery) bought new batt, made sure it was charged to 12.8 volts, installed, and still no change. Any ideas? Any help appreciated
