jedd_imp said:
NickLHG_imp said:
Houtman_imp said:
Your batterie is a 12 volt one and I like the Optimate / Tecmate batterie chargers . Check them out online.
sweet thank you. Another question for you.. my 2014 dlx just arrived today. Is it a CB1100 SA AC? Or it is a CB1100 AC? I’m looking at some oem parts on Babbits.com.
If I’m correct it’s a CB1100 SA but I’m not sure exactly what the AC is.
I get confused almost everytime I go to look for DLX oem parts.
NOw after the parts loads up, I view "EXHAUST" category, and see if qty=2 . This helps me confirm that I'm viewing the DLX parts fische.
A couple yrs ago when my oem battery died, i sprung for the lithium battery. no more battery tender! :beerchug:
Wait.. you won’t need a battery tender if you use a lithium? Didn’t know you could use a lithium battery at all. Do you happen to have a link of the battery that will work with the dlx? Definitely interested one day.
My bike is now 6 years old with 3406 miles on it, how often do I replace the battery? Every someodd years or x miles?
Thanks for the help guys. I ordered the tender off jpcycles.. will be returning when I get it as I’ll be able to purchase 25.00 cheaper on amazon. Should’ve done more research before purchasing.
