Battery Tender USB under the seat question
Cras_imp
I went ahead and installed the battery tender harness + the battery tender USB for my iPhone to use as a GPS.
If I leave the phone cable plugged into the USB tucked in the little area under my seat, would it be pretty secure from water during rain? Or do I have to give it additional protection from the rain?
Does it have a waterproof cap? If not I would think you'd want to provide additional protection
Hey Cras,
I have the same setup as what you're talking about. At least I'm assuming you're talking about this:
The question I would ask everyone here is if anyone has had any experience with water/moisture getting into the storage compartment?
I would expect that your USB connector fits the same as mine so there would also be a bit of the metal exposed. Clearly, this is not a water tight connection so if I ultimately decide to keep this a permanent (or even semi-permanent) connection, I will figure out a way to make the connection more water resistant.
