The front disk brakes on the non-ABS model use five 6mm x 18mm Torex bolts. I want to remove the bolts to pull the collars and paint the collars gold - or find someone that will anodyze them.
Any suggestions for finding a 6mm Torex wrench? I'm reluctant to use a Torex bit. I think the bolts will require some force to remove and I'd like a solid one piece wrench - think hex wrenches. I don't want to bugger them up.
I've found torex wrench sets but they are on the pricy side and all I'll ever need is a 6mm Torx.
I tried some auto supply dealers, no luck.
Thanks in advance for your help
