Razor
Been there
The Honda CB350 seemed to a good starting point. After talking with a good friend... he just happened to have one. A few minutes of negotiation, and a 1972 CB350 made it home.
Mono shock rear from 2000 CBR600
Inverted front forks with dual disc brakes (yes, I love overkill) 2008 GSXR750
Used CBR rear wheel being blasted before powder coat
Some frame mods, machined a few parts, and it's starting to look like something
Engine disassembled. Ready for cleaning & inspection
Took me a while, found a 1970 CB350 tank.
Extended the counter shaft to align the sprockets
Here's where the project stands.
All the lights will be LED. The headlight has three super bright LED's. Low beam is top, single, high beam is all three (blinding). The GSXR has a "pass" switch on the left control. Normally it flashes the high beam, but might use it to engage a strobe through the turn signals.
Tach/Speedo is from SpeedHut. Larger gauge is the tachometer. Unit has a rev light, turn signal indicators, high beam and an LCD display with multiple functions.
