peterbaron
Road warrior
My 2024 Z650RS was made in Malaysia
I wouldn't be myself if I didnt remove some trims+ to look inside in case of minor road emergency.
I already ordered USB charger and then, I will have to remove the gas tank, 2 bolts and a high pressure fuel line disconnection.
The headlamp bucket does not have any B+ outlet at all, only 4 connectors there , 2 for L & R turn signals and an LED sockets.
Cluster, gauges and clock are very easy to read. The speedo has no miles, so most likely US version has no kms...
All cluster setting can be done by thumb and while holding the handle bar
Very easy acces to the battery^, after swinging aside an electric box that sits on top of it
I already secured the seat cable by inserting a piece of hard sponge
Simple tool kit
Easy access to the starter motor
L-top is a B+ outlet....coolant overflow and rear brake reservoirs
Water pump..???
Engine oil level sight glass
Some specs...
Love this tire
The chain slack can be adjusted while on the side stand
Easy access to drain engine oil
The oad report is coming next week, so far I clocked 680 kms
:biker:
Simple tool kit
Water pump..???
Some specs...
Love this tire
:biker:
