CotswoldPhoto_imp
New to the forum
Has anybody take the top off one of these Showa dual bending valve forks?
Being a somewhat short person (27" inseam), I can just get my toes down.
The rear shocks (with the piggyback can) are 360mm and I have acquired some 315mm replacements, which should give me maybe 1.5" lower seat height.
But, I would also need to reduce the front forks by the same. As the front and rear suspension is about the same angle/rake, I would guess I need to reduce the preload on the front forks by much the same.
Lifting the handlbar away looks easy enough from the workshop manual. Off with the covering caps and undo the four top bolts and lift it away.
The only technical drawing I can find of this make and type of shock is off a Harley.
It looks like it has a preload tube at the top, so replacing that with a shorter one should do it, but how much shorter? My guess is, maybe only an inch shorter.
I just wondered if anybody else has been inside the shock before I give this a go. Winter is starting to bite where I am, so I'm not often out on the bike anyway.
