K&H Hi seat and gauge covers arrived!
RetroSeattle_imp Offline
Threads: 17
I received another magic box from Takashi at Samurider with my new K&H Hi seat, and my chrome gauge covers.
The workmanship on the K&H seat is wonderful and it fits perfectly. I haven't done a test ride yet, but the garage sit test confirms that the higher seating position un-kinks my long legs.
Samurider gets my vote as the best and most responsive parts supplier. Expensive, and worth it.
Has anybody done a headlight aiming exercise?
02-24-2015, 06:52 AM
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Given: 142
RE: K&H Hi seat and gauge covers arrived!
The red stitching in the seat really looks good on that red bike. Thumbs Up
02-24-2015, 06:55 AM
Likes Given: 789
Beautiful!
as for headlight aiming, I only worry about the high beam. If its dark I want to see as far as I can clearly on high beam... so I go out at night, leave my headlight loose enough I can move it, and stick an allen in my pocket. Stop on a long flat stretch of road where there are no streetlights, and raise the headlight for best view in those conditions and then tighten it there. It's easy to tell when you have it right.
02-24-2015, 07:23 AM
Threads: 17
Following an hour ling ride I can confirm that the K&H Hi seat is an improvement for me. I have long legs and my knees don't feel as bent with this one. I will have to make a longer journey soon to check on the time between leg stretching stops. Biker
02-24-2015, 01:11 PM
gossman_imp Offline
Threads: 16
Love the seat and really interested in the way you got the bike up on the centerstand while on the dolly. Is it as hairy as it looks?
02-24-2015, 01:27 PM
Threads: 17
No problem, I just make sure that the center stand feet are centered on the dolly and give her the old heave ho. I am 6'4" and 235 pounds so have a bit of an advantage there. The dolly really makes it easy to move things around in the ManShack.
02-24-2015, 02:20 PM
gossman_imp Offline
Threads: 16
(02-24-2015, 02:20 PM)RetroSeattle_imp Wrote: No problem, I just make sure that the center stand feet are centered on the dolly and give her the old heave ho. I am 6'4" and 235 pounds so have a bit of an advantage there. The dolly really makes it easy to move things around in the ManShack.
I'm 6'4 and 326 so it shouldn't be an issue here either. Time for harbor freight now.
02-24-2015, 03:37 PM
Likes Given: 1,011
Headlight aiming: http://cb1100forum.com/forum/showthread.php?tid=905
02-24-2015, 06:20 PM
bikerdave_imp Offline
Threads: 2
Dear Retro, Where did you get the dolly? It really looks like a good idea. And I'll really bet it helps in moving things around in the cave.
02-27-2015, 10:31 AM
Lord Popgun Offline
Virginia
Likes Given: 142
Probably here: http://www.legalspeeding.com/Park-n-Move.htm
02-27-2015, 10:51 AM
  Gauge Mods Seancampbell777_imp 11 1,107 10-16-2024, 04:14 AM
  2017 CB1100EX Color matched side covers ceeko_imp 66 4,291 06-25-2023, 10:17 PM
  Corbin seat arrived and....... Ollie 9 775 07-22-2022, 01:03 AM
Last Post: Ollie
  improved seat and 3 cm higher SEAT. the best reform Alfgaxatico_imp 1 312 04-25-2021, 04:47 AM
  Parcel arrived today Mixagon_imp 11 1,070 03-07-2021, 10:03 PM
  side covers plastic or aluminium? mrded_imp 8 711 10-03-2020, 11:33 AM
  Adding an oil pressure gauge wiscoaircraftmech_imp 7 578 06-30-2020, 01:41 AM
Last Post: wiscoaircraftmech_imp
  Aftermarket Brake and Clutch Reservoir Covers michael1954 11 950 06-17-2020, 08:42 AM
Last Post: Mtneers
  Side Covers YotaMan_imp 42 2,698 05-16-2020, 08:59 PM
Last Post: Guth_imp
  Designing an Engine Oil Temperature Display Gauge Project 17-CB-002 37 2,467 11-06-2019, 04:10 AM
