Adding an oil pressure gauge
wiscoaircraftmech_imp Offline
New to the Forum
Threads: 1
Hello everyone,
Just purchased a beautiful 14' STD and was curious about adding an oil pressure gauge to keep an eye on things. Does anyone know of an oil galley plug I can remove to install one or better yet, a way to tap into an oil cooler lines. Just curious.
Glad to be a part of the group!
-Nick
06-25-2020, 05:37 AM
the Ferret Online
Threads: 698
Likes Given: 792
RE: Adding an oil pressure gauge
Hello Howdy and welcome to the forum.
Someone may know something about that. Can't remember anyone having done it to one of these. Oil pressure hasn't been a problem with these and the bike has been out since 2010. We have a couple members with over 100,000 miles on their bikes.
06-25-2020, 05:43 AM
Cormanus Online
Likes Given: 1,014
Welcome to the forum, wiscoaircraftmech.
06-25-2020, 06:52 AM
peterbaron Offline
Likes Given: 996
Hello and welcome to the forum, wiscoaircraftmech....
Oil pressure switch is located at R/F bottom as per pic, covered by the black rubber boot and indicated by green s-driver knob::
[Image: 90ea9b72edfd8b41076b2bac39537738.jpg]
or without boot:
[Image: 2b9d851f9cbac550272d3fe45bce3d0e.jpg]
Have fun.
06-25-2020, 07:04 AM
max Offline
Threads: 39
Likes Received: 15 in 8 posts
Congrats W.M. the bike has an oil pressure regulator which maintains pressure at a set level, depending on which part of the engine you want to monitor you may find a place downstream of the pump which is meaningful to keep an eye out for.
Also adding something to the oil system may increase the risk of that part failing and causing a problem but judging by your nickname you would be familiar with that scenario.
I think popgun had a diagram of how the oil is routed in our bikes, it may not be what you expect since the sparkplugs are oil cooled too on our bikes, maybe he can find it again or you can search for it with the search at the top of this page.
And since we are in oil territory i would add a warning not to use these k&n oil filters with a hexagon nut spotwelded to the top to make it easy to remove them, they fail spectacularly on a regular basis and this is well documented if you did not know this already.
06-25-2020, 07:58 AM
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Given: 142
Max, that oil routing diagram is in the service manual. I’ll go take a look at it. It is in section 4.
It actually shows that we have 2 oil pumps in one. The Cooler Pump sends oil to the oil cooler (go figure Smile ) and spark plugs, and the Feed Pump whose output goes to the oil filter. The EOP switch is mounted at the end of the oil filter output and after 2 tees that send oil to the the rest of the engine.
The EOT switch is mounted on the output line of the spark plug output ( or, the path is sump to oil cooler to spark plugs to the sump. EOT is between the spark plugs and sump.
In looking at the bike, there are a few gallery plugs that could possible be used, but I don’t know. Unless someone knows, I would think you might need a service manual to look at the oil flow diagram and crankcase, etc. sections to figure it all out.
Wisco, we cannot post copyrighted material. If you would like to see the flow diagram, PM me.
06-25-2020, 09:14 AM
Charlie Bravo_imp Offline
Threads: 30
I had a sailboat with a diesel engine with a low-pressure alarm that I wanted to add a gauge to. I "T" into the alarm port, added my own sender unit, and ran a wire up to the cockpit. Worked great.
06-27-2020, 02:52 AM
New to the Forum
Threads: 1
Thank you for the pictures! Im setting up my own custom wiring and lines. I'll keep you updated.
06-30-2020, 01:41 AM
  Gauge Mods Seancampbell777_imp 11 1,128 10-16-2024, 04:14 AM
  FOBO tire pressure monitoring system report.. Chuckk_imp 120 8,415 11-28-2020, 10:38 AM
Last Post: Chuckk_imp
  Designing an Engine Oil Temperature Display Gauge Project 17-CB-002 37 2,515 11-06-2019, 04:10 AM
  2017 Chrome Gauge Covers on a 2014 suhawk305 12 877 08-01-2017, 12:27 PM
Last Post: run-tmc_imp
  Adding original decals on the new CB's af_one_imp 2 326 07-24-2017, 10:39 AM
Last Post: af_one_imp
  Oil Temperature Gauge Paul_imp 12 874 03-18-2017, 12:29 PM
Last Post: BestStandard_imp
  Adding a Dash Cam - Rexing V1 on CB1100 EarsOnWheels_imp 12 789 08-10-2016, 12:35 AM
Last Post: Riko_imp
  Gauge Cover baginn_imp 5 446 04-27-2016, 04:56 AM
Last Post: 0011bc_imp
  Oil Pressure/Temperature guage???? bikerdave_imp 47 4,082 06-11-2015, 12:28 PM
Last Post: flynrider
  K&H Hi seat and gauge covers arrived! RetroSeattle_imp 13 969 02-28-2015, 01:35 AM
Last Post: Rocky_imp
