side covers plastic or aluminium?
mrded_imp Offline
Threads: 7
Likes Received: 2 in 2 posts
I noticed that airbox side covers on 2019 models is aluminium, where 2017 model has plastic airbox side covers. See pictures.
Out for curiosity:
- Does 2019 models have plastic side covers? (not airbox, another one with fuses)
- Can an aluminium airbox side covers be installed to 2017 models? To make fully aluminium version.
07-22-2020, 03:53 AM
Rox_imp Offline
Threads: 3
RE: side covers plastic or aluminium?
I would love to replace my plastics for aluminum.
07-28-2020, 01:56 AM
Threads: 349
Likes Given: 1,034
mrded, you may well not get an answer to this question as the majority of members are in the US which has never seen the RS. You could try emailing Mr Takashi at Samurider.com. He may well know the answer and also be able to get the parts for you.
07-28-2020, 06:57 AM
treedoc_imp Offline
Threads: 9
I also would like to replace the plastic covers on my rs, they cheapen it where everything else looks classy.
07-29-2020, 06:23 AM
E11even_Hunnit Offline
California
Threads: 5
Likes Given: 34
All 4 aluminum covers would look bad*ss indeed, too bad the'd run $500+
07-31-2020, 01:08 AM
Threads: 349
Likes Given: 1,034
Yes, but would they fit?
Can someone help? I reckon they might well fit, but I can’t be certain.
07-31-2020, 09:43 AM
mrded_imp Offline
Threads: 7
Can someone with a new CB1100 > 2019 take pictures of side panels and bolts inside?
I want to check if it fits older models. Thanks.
10-03-2020, 08:40 AM
pekingduck Offline
Southern California
Threads: 41
Likes Given: 39
The 2019 triangular side covers are aluminum, same as 2017.
The 2019 aluminum airbox covers bolt to an interim plastic piece that attaches to the airbox in the same way - 2 tabs at the lower edge and a push-pin clip at the top. Actual airboxes are the same for all years, so should fit all years.
17241-MGC-JQ0 and 17242-MGC-JQ0 for R & L aluminum covers respectively.
17245-MGC-JQ0 and 17245-MGC-JQ0 for the interim plastic pieces, R & L.
Plus you'll need 4 screws 90118-MKJ-D00 and 4 nuts 90016-ZA5-000.
They'll run you just shy of 400 GBP for the set, about $517 US....... I suddenly like the originals much better.
10-03-2020, 11:00 AM
(10-03-2020, 11:00 AM)pekingduck_imp Wrote: The 2019 triangular side covers are aluminum, same as 2017.
Yikes!
Man, I remember ordering colour matched Yamaha side covers direct from Japan for about $40 US each, including shipping.
10-03-2020, 11:33 AM
  2017 CB1100EX Color matched side covers ceeko_imp 66 5,058 06-25-2023, 10:17 PM
  Aftermarket Brake and Clutch Reservoir Covers michael1954 11 1,082 06-17-2020, 08:42 AM
Last Post: Mtneers
  Side Covers YotaMan_imp 42 3,099 05-16-2020, 08:59 PM
Last Post: Guth_imp
  Aluminium side covers for 2014 Houtman_imp 8 637 08-15-2019, 02:00 PM
Last Post: Desert viper_imp
  Installed red side covers on 2013 CB1100 Frulk_imp 15 1,353 10-05-2018, 02:54 PM
  Advice for removing emblems on side covers misterprofessionality 26 2,158 05-01-2018, 07:28 AM
  Dremeled my side covers- what do you think? PowerDubs_imp 71 4,510 02-22-2018, 03:19 AM
  Force Design air cleaner covers and side covers Bheezy27403_imp 12 1,000 02-19-2018, 01:44 AM
Last Post: Bheezy27403_imp
  Need help with part number for side covers jedd_imp 2 354 11-27-2017, 10:08 AM
Last Post: jedd_imp
  Bolt/Nut Black Plastic Domed Caps 2017EX_imp 5 500 11-22-2017, 02:37 AM
Last Post: 2017EX_imp
