POSH Classical Turn Signal Kit
mjezek_imp Offline
Threads: 6
Figured i post some pics from my installation.
Rear Turn Signals is very straight forward and easy, but you do have to remove the battery tray.
Front Turn Signals, it's a little bit tricky and you will need a drill. The hole of the OEM Mount is too small .... good thing you will still be able to use the original turn signals ...
But they look soon much better then the large OEM Turn signals ...
I also enjoy the "challenge" to follow the japanese instructions but with just a little bit of common sense it's a walk in the park.
Mr. T and Samurider.com rocks and is the death of my credit card !
04-03-2015, 11:19 AM
the_undecider_imp Offline
Threads: 43
RE: POSH Classical Turn Signal Kit
Nice! I was looking at the silver version of those and was scared off not knowing what modifications were needed. Changing the big OEM signals are the final cosmetic mod I was considering, but the recent farkle spree I went on with my other bike has set that back. I was still considering the smaller OEM signals of a 2014 since they should be a more direct swap. How bright are these Posh signals compared to stock?
04-03-2015, 11:21 PM
mjezek_imp Offline
Threads: 6
(04-03-2015, 11:21 PM)the_undecider_imp Wrote: Nice! I was looking at the silver version of those and was scared off not knowing what modifications were needed. Changing the big OEM signals are the final cosmetic mod I was considering, but the recent farkle spree I went on with my other bike has set that back. I was still considering the smaller OEM signals of a 2014 since they should be a more direct swap. How bright are these Posh signals compared to stock?
Since I have the darker glass, they might be a little bit less bright, but to my eyes it pretty much looks the same ...
04-03-2015, 11:41 PM
Pterodactyl_imp Offline
Threads: 75
Well done. That is an interesting look.
04-04-2015, 08:02 AM
  Turn Signal Indicators balkanhound_imp 5 642 04-17-2025, 11:17 PM
  2014 CB1100 Clear Turn Signal Lenses Ngavrielidis1_imp 16 1,448 04-15-2025, 06:23 AM
Last Post: Ngavrielidis1_imp
  Smaller turn signal/running light choices TxRonHarris_imp 33 2,390 07-06-2021, 10:00 PM
  Extra turn signal on dash Mixagon_imp 7 688 06-24-2021, 07:20 AM
Last Post: 17-CB-002
  Turn Signal Relocation Cormanus 11 817 12-30-2020, 11:12 AM
  Signal Relocation Ben70_imp 7 719 02-20-2020, 10:22 AM
Last Post: Ben70_imp
  Turn signal relocation -- Making room for my backseat rider JMA_imp 13 944 06-15-2019, 12:44 PM
Last Post: QUINTtastic_imp
  Where to tap speed sensor signal? egleaves_imp 93 4,844 10-19-2018, 08:49 AM
  Turn Signal Swap - Blown Fuses grover_imp 21 1,131 06-20-2018, 07:37 PM
  Fast flashing turn signal cafe74_imp 9 715 05-27-2017, 04:13 PM
Last Post: CSODenmark_imp
