Fast flashing turn signal
cafe74_imp Offline
Threads: 3
I would think this is not a new program but not sure what the fix would be . I installed aftermarket led Tim signal's and now it flashes fast . I believe a resistor would be used but do I need 4 of the or just 2 . And is there a better resistor than others.
Thanks for the help
03-29-2017, 08:12 AM
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Given: 142
RE: Fast flashing turn signal
Read this and a couple of posts down: http://cb1100forum.com/forum/showthread....#pid165009
And this thread: http://cb1100forum.com/forum/showthread....3#pid82823
One member says to wire them in parallel and another in series. I would imagine either way would work, or you may have to try both to get the best results. Hopefully one of them will chime in. Here is a link with a pictorial wiring diagram on how to wire them in parallel, which to my technician mine is the correct way: http://www.plasmaglow.com/install/instal...sistor.pdf
You will need one resistor per light to present the proper load to the 'flasher' (turn signal posistion relay).
03-29-2017, 08:18 AM
geosar_imp Offline
Threads: 10
I purchased mine at Autozone.
They come two in a pack. I installed them in parallel in each two wire circuit going to the blinkers. The main warning is that the resistors can get hot, I insulated mine to protect the rest of the undersea area.
Almost think a little heatsink would protect the resistors.
George
Arizona
03-29-2017, 09:50 AM
cafe74_imp Offline
Threads: 3
My concern is that with the front lights also being on all the time the resistor would be really hot after time on a ride the posh relay is an idea but expensive. If I add more lights into the system that would bring up the residents.. plenty to think about
03-29-2017, 10:51 AM
Lord Popgun Offline
Virginia
Likes Given: 142
Buy the POSH flasher referenced one of the threads I posted. Problem solved.
03-29-2017, 11:21 AM
CSODenmark_imp Offline
Threads: 2
(03-29-2017, 11:21 AM)Lord Popgun_imp Wrote: Buy the POSH flasher referenced one of the threads I posted. Problem solved.
I just installed the POSH. Rear blinkers work perfect, but front always lights up, except when flashing. When the front blinkers is not activated they still get 12v from the relay. I guess a defect POSH??
Any ideas?
Best regards
Carsten
05-25-2017, 06:40 AM
Lord Popgun Offline
Virginia
Likes Given: 142
In the US at least, the front signals are always on (unless one is flashing for a turn Smile )
Are they not like that in Denmark?
05-25-2017, 08:18 AM
Likes Given: 1,010
Carsten, I think I'm right in saying that US law requires that the front indicators on a motorcycle must be on except when flashing. It may be that the POSH relay is built to make sure that happens?
In Australia, our front indicators are off except when they're flashing.
05-25-2017, 08:20 AM
Lord Popgun Offline
Virginia
Likes Given: 142
Cormanus, I think you are on to it. And now I know the bikes are not all wired the same in all countries for all functions.
05-25-2017, 08:22 AM
Threads: 2
(05-25-2017, 08:22 AM)Lord Popgun_imp Wrote: Cormanus, I think you are on to it. And now I know the bikes are not all wired the same in all countries for all functions.
Thank you all!
Sure, it the right answer! However, I was confused because one the front blinkers was working in the beginning. Nevertheless, I have decided to run with this, let’s see if the Danish police will give me a thumbs up for the bike design.
05-27-2017, 04:13 PM
  Turn Signal Indicators balkanhound_imp 5 700 04-17-2025, 11:17 PM
  2014 CB1100 Clear Turn Signal Lenses Ngavrielidis1_imp 16 1,536 04-15-2025, 06:23 AM
Last Post: Ngavrielidis1_imp
  Smaller turn signal/running light choices TxRonHarris_imp 33 2,651 07-06-2021, 10:00 PM
  Extra turn signal on dash Mixagon_imp 7 745 06-24-2021, 07:20 AM
Last Post: 17-CB-002
  Turn Signal Relocation Cormanus 11 919 12-30-2020, 11:12 AM
  Signal Relocation Ben70_imp 7 767 02-20-2020, 10:22 AM
Last Post: Ben70_imp
  Turn signal relocation -- Making room for my backseat rider JMA_imp 13 1,031 06-15-2019, 12:44 PM
Last Post: QUINTtastic_imp
  Where to tap speed sensor signal? egleaves_imp 93 5,531 10-19-2018, 08:49 AM
  Turn Signal Swap - Blown Fuses grover_imp 21 1,315 06-20-2018, 07:37 PM
  Front turn signal mounting hole diameter c-breezy_imp 7 615 04-23-2017, 05:26 AM
Last Post: c-breezy_imp
