Battery Tender USB under the seat question
Cras_imp Offline
Threads: 3
I went ahead and installed the battery tender harness + the battery tender USB for my iPhone to use as a GPS.
If I leave the phone cable plugged into the USB tucked in the little area under my seat, would it be pretty secure from water during rain? Or do I have to give it additional protection from the rain?
04-07-2015, 01:44 PM
Threads: 698
Likes Given: 792
RE: Battery Tender USB under the seat question
Does it have a waterproof cap? If not I would think you'd want to provide additional protection
04-07-2015, 08:30 PM
JPX_imp Offline
Threads: 7
It has a cap for the USB connector but I don't think it's IP rated for dust/humidity
04-07-2015, 10:45 PM
Setchman_imp Offline
Threads: 4
(04-07-2015, 01:44 PM)Cras_imp Wrote: I went ahead and installed the battery tender harness + the battery tender USB for my iPhone to use as a GPS.
Hey Cras,
I have the same setup as what you're talking about. At least I'm assuming you're talking about this:
The question I would ask everyone here is if anyone has had any experience with water/moisture getting into the storage compartment?
I would expect that your USB connector fits the same as mine so there would also be a bit of the metal exposed. Clearly, this is not a water tight connection so if I ultimately decide to keep this a permanent (or even semi-permanent) connection, I will figure out a way to make the connection more water resistant.
04-07-2015, 11:42 PM
  USB ON HANDLEBAR - connection at battery direct . Alfgaxatico_imp 38 2,862 05-17-2026, 10:20 PM
  Usb-c cable direct to battery or switched power capz65_imp 5 568 04-16-2022, 02:26 PM
  my deluxe is broken... missing battery box cover!! Sparky80_imp 6 614 10-13-2021, 02:09 AM
  improved seat and 3 cm higher SEAT. the best reform Alfgaxatico_imp 1 315 04-25-2021, 04:47 AM
  Tender for my Battery Tender LongRanger_imp 3 338 02-04-2017, 12:46 PM
Last Post: White Dog_imp
  Battery Tender pigtail installation AKB_imp 12 991 01-30-2017, 10:55 AM
Last Post: AKB_imp
  Battery Charger - Inexpensive rbike_imp 0 218 12-20-2015, 10:19 PM
Last Post: rbike_imp
  SparkBright Battery Voltage Monitor Setchman_imp 7 674 04-30-2015, 04:19 AM
Last Post: Setchman_imp
  K&H seat question fredkb_imp 1 188 05-18-2014, 03:56 AM
Last Post: CB4ME_imp
