Motogadget Handlebar-end Blinkers
Gsnyder70_imp Offline
Threads: 5
Anyone have any experience with blinkers that are mounted on the end of the handlebars? Here is a link to some made by Motogadget:
http://motogadget.com/en/turn-signal-lig...-disc.html
Revival Cycles appears to be the U.S. sales agent, but there may be more.
They are kind of pricey but look cool, but they bring up one important question in my mind that I was hoping someone could help with. In order to run the lights to the ends of the handlebars, a hole needs to be drilled in the bars to let the wires out to be connected to the wiring harness. Will this hole weaken bars to a dangerous level? The install guide recommends a 3mm hole, but I found a link to a build where the hole is much larger, see the picture attached. Here is a link to the build:
http://revivalcycles.com/pages/homegrown...onda-cb750
At the very least I figured I'd share this cool build and parts.
12-30-2015, 08:56 AM
  USB ON HANDLEBAR - connection at battery direct . Alfgaxatico_imp 38 3,326 05-17-2026, 10:20 PM
  Quad Lock handlebar vs clutch perch and bar-end mirrors Uncle Sixer 1 353 01-04-2026, 01:26 PM
  Handlebar control symmetry Uncle Sixer 17 1,921 08-07-2025, 05:24 AM
  Handlebar Risers?? bubblerboy64_imp 16 1,786 07-16-2022, 06:04 AM
Last Post: calipo223_imp
  What to do with the handlebar mounts when converting to clip-on controls? misterprofessionality 7 834 04-08-2022, 03:41 AM
  CB 1100 EX Handlebar original or other? MALACAY_imp 4 597 04-03-2022, 01:00 AM
  Handlebar from 919 motorider6_imp 10 1,046 05-27-2021, 12:47 PM
Last Post: Stichill
  CRF1000 handlebar mspaansnl_imp 0 251 05-25-2021, 04:57 AM
Last Post: mspaansnl_imp
  HANDLEBAR RISERS - is really necessary??? Alfgaxatico_imp 19 1,640 12-16-2020, 10:40 PM
  Early 80’s handlebar clamp PowerDubs_imp 33 2,566 10-10-2020, 02:36 AM
Last Post: Gordo_imp
