16,000 Lumens Spot Lights to complement 2017 Led headlights
17-CB-002 Offline
Threads: 45
Since the 2017 and later CB's are equipped with LED headlights, lots of owners complained of poor illumination and worst the electrical wiring diagram does not properly explain its operation, so after some research I decided to install a pair of "Motowolf" auxiliary spot lights.
Each light is rated at 7,800 lumens (@ 6,500 kelvins - white lights) and projects to a maximum of 300 meters while consuming only 45 watts (9 LED's), the pair is sold for around $60.00 USD from their US depot.
After the installation & aiming, I tested on roads with no street lights and to say the least, I very happy with the result.
Note: Better result can be obtained if the spotlights were located farther apart from each other.
Pictures are taken under different conditions; Low beam, High beam and the spotlights.
Low Beam
[Image: 093e376567af1196261b96a5f1d57487.jpg]
High Beam
[Image: ad80e7237f7d49cc6fe4191df9ccaa4d.jpg]
Spotlights
[Image: 8b92e8c0365db02e46a5fe9436517854.jpg]
Spotlight
[Image: 044a0d36e5860c880e6aa5c158a63e95.png]
On bike
[Image: 97c48c1d46a4b08385e0ae40a1c30ac8.jpg]
08-09-2020, 02:04 PM
Houtman_imp Offline
Threads: 115
RE: 16,000 Lumens Spot Lights to complement 2017 Led headlights
This looks like the Toronto light house ! Well done , the only problem I start to see is that many bikes have such a large amount of lights on their bikes and do not put them on low beam in tunnels that it gets dangerous for riders coming from the opposite direction. I see this a lot on the BRP.
08-09-2020, 08:40 PM
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Given: 142
Alain,
I have to ask about the hardware mounting your front camera to the mount. Mine did not come with a long screw and nut. Mine has a shorter screw that threads into one side of the camera clamp. Did yours come with that long screw?
08-09-2020, 09:35 PM
17-CB-002 Offline
Threads: 45
(08-09-2020, 09:35 PM)Lord Popgun_imp Wrote: Alain,
The longer bolt was not included in the kit, I had one in my tool box.
I only used the knurled knob screw from the kit to attach to the bolt and disregarded everything else.
From the picture you can see that the bolt was a bit too long, i will have to cut it to proper length during the winter season.
Everet, see your personal email for more pictures.
(08-09-2020, 08:40 PM)Houtman_imp Wrote: This looks like the Toronto light house ! Well done , the only problem I start to see is that many bikes have such a large amount of lights on their bikes and do not put them on low beam in tunnels that it gets dangerous for riders coming from the opposite direction. I see this a lot on the BRP.
Yes, I hate that blinding lights too.
I do have a switch conveniently mounted so that I can easily and quickly turn it off so as not to blind the oncoming traffic.
Switch is part of the same clamp that holds the clutch reservoir.
08-10-2020, 03:49 AM
mvk24_imp Offline
Threads: 18
Likes Received: 2 in 1 posts
Do you have a write up for how you wired up the lights and switch? I've been wanting to add 2 fog/spot lights to my 2014 for awhile now
08-11-2020, 04:25 AM
mvk24_imp Offline
Threads: 18
Also did you use a relay and fuse or did you just hardwire it to the switch?
08-11-2020, 05:42 AM
17-CB-002 Offline
Threads: 45
(08-11-2020, 05:42 AM)mvk24_imp Wrote: Also did you use a relay and fuse or did you just hardwire it to the switch?
Yes, will require separate fuse.
All power wires are available in the headlight bucket.
Hope it help
Regards
Alain Lee
Let me know of where you hide the extra long "Manual switch & GPS" wires.
I did hide mine behind the headlight bucket, but still looks ugly.
For the front camera, I riveted the lens base to the headlight bucket and
for the rear, I riveted it on the tail light lens cover.
Also, for the GPS "Time" setting, I selected the -4 hours for Toronto.
(08-11-2020, 04:25 AM)mvk24_imp Wrote: Do you have a write up for how you wired up the lights and switch? I've been wanting to add 2 fog/spot lights to my 2014 for awhile now
Hi MVK,
Since I installed quite a few accessories on the CB and I did not want to tamper with the factory wirings, I made an external "auxiliary" waterproof electrical box located between the rear shock and the air filter cover.
All my accessories (relays & fuses) goes through it.
08-11-2020, 06:48 AM
mvk24_imp Offline
Threads: 18
Hope it help
Regards
Alain Lee
Hi MVK,
Hope it help
Regards
Alain Lee
Hi MVK,
All my accessories (relays & fuses) goes through it. Very cool, i have looked into an external fuse box for my jeep in the past and now my Forester XT to clean up all the auxilary wiring running from the battery. This might be a good excuse to try it even though I only plan on running 1 pair of those 60w lights. I found them on Amazon for 41$ with prime shipping.
I suppose I will order one of those pre-made harnesses for 17$ to keep the relays and fuse nice and tidy as I've used them in the past on the subaru.
Did you use one of those handbag mounted switches?
I appreciate the advice above to run my power from the headlight bucket but I also don't want to mess with factory wiring.. (ask me how I know) damn jeeps lol
08-11-2020, 08:08 AM
Lord Popgun Offline
Virginia
Likes Given: 142
Alain, I did not connect the manual switch and haven't decided if I'm going to connect the GPS so don't have to deal with those cables.
I also did not mount mine on the handlebars. I used the "put it in the tool box" option as I don't intend to watch the vids while riding. I can access them on the iPhone if I want to look at them.
Mounting the cameras--My bike has a Honda rack with a Givi box on the back and a Road Comet fairing on the front. For the rear camera I mounted the camera on the left side of the brake light-the chrome part, on the bevel line. After taking the light out for inspection, I put it back and drilled 1/16" holes and screwed the mount on. Yes, the screws are just long enough to go into the black part of the lens so I'll have to remove them to change a bulb.
In front, the fairing limits mounting options, in my case, so I ditched the camera "T-Mount" and use the handlebar mount for the display/recorder. I had to modify it slightly as the screw it uses does not work with the camera. So I drilled the non-threaded hole and the middle hole to fit the camera screw. I left the threaded hole alone so it can be used later if the needed. Then, I removed the 2 allen screws and reversed the mount on the handlebar mount. This was to keep the screw head on the outside of the bike so it would look better. I had to do that as I mounted the thing upside down. Then I mounted the handlebar mount on the right side of the bike on the base of the rubber part of the turn signal light. Then installed the camera on it.
Excess cable: I didn't have much excess camera cable after running them to the tool box and did not need to use the 2 meter cable. The power cable they supply is looong. For those not knowing, there is a little "power box" on the cable. One side has the power connections and the other has multipin plug for the display unit. Anyway, I cut the 3 wire side to length and the other I coiled up and it is pushed on top of the fuse panel under the frame cross brace. All the other excess is in the tool box with my small tool bag.
Connection power was easy in my case. Always on power (red wire) is connected to the + battery terminal. Ground and switched +12v I pulled from the accessory connector which is right under the tool box, under the fuse panel. As I have a connector kit, I pinned the 2 wires and plugged in the connector and tested it out. Tested good!!
I know you know this Alain. They also supply a power connecter with a USB port so you can power the unit on with a phone charger. That made it easy to play with the device and setting the options before mounting anything.
08-11-2020, 10:17 PM
17-CB-002 Offline
Threads: 45
Hi MVK,
You already have the connector available there in the headlight bucket for that exact purpose. Other members bought the female connector to fit that "option" connector (there is a tread somewhere in this forum). This is is the supply power to your spot lights.
The headlight wire is required to power the switch side of the relay. - You do not want to leave the spot light "ON" by mistake and also to be legal with the law. - No spot light when on high beam.
This switch is also available without the M10 port.
Switch mounted to "Clutch Reservoir" clamp. (neat)
[Image: 3a67fb62992295702743ecf9eabbe058.png]
08-12-2020, 04:01 AM
  Additional front driving lights Davidjill_imp 6 661 08-28-2024, 12:46 PM
Last Post: michael1954
  Where to mount auxiliary lights Gone in 60 42 2,560 04-20-2021, 09:17 PM
  2017 CB1100EX Clearwater Darla Lights Install TXBikerGuy 7 661 07-25-2020, 08:51 AM
Last Post: TXBikerGuy
  Advice on aux Brake lights. hawk123_imp 6 761 08-18-2019, 04:03 AM
Last Post: hawk123_imp
  amber LED fog lights Chuckk_imp 14 1,309 06-20-2019, 01:46 AM
  Choice of Fog /Accessory Lights Ennsync_imp 5 524 10-16-2018, 05:20 AM
Last Post: Ennsync_imp
  Installed Denali D2 driving lights bflint 9 861 08-05-2018, 02:58 AM
Last Post: bflint
  Added Denali Running Lights Mscb1100_imp 3 450 03-27-2018, 12:39 PM
Last Post: Mscb1100_imp
  LED Headlights Spiderwatts_imp 24 1,796 12-10-2017, 06:11 AM
Last Post: Spiderwatts_imp
  upgrade head lights? bflint 4 422 04-08-2017, 02:21 PM
Last Post: bflint
