Ignition Starter 2017 on 2013 Bike
cb1100_dude_imp Offline
Threads: 10
Hello,
Does anyone know if a 2017 ignition key starter will fit on a CB1100?
Looking to buy a new 2017 with matching gas cap so I can only use one key for my 2013 bike with the newer gas tank.
Thank you!
L
02-06-2019, 01:33 AM
SportsterDoc Offline
New Mexico
Threads: 33
Likes Given: 6
RE: Ignition Starter 2017 on 2013 Bike
They are different part numbers, but I do not know what the difference(s) may be
https://www.hondapartshouse.com/oemparts...top-bridge
02-06-2019, 01:48 AM
Threads: 10
(02-06-2019, 01:48 AM)SportsterDoc_imp Wrote: They are different part numbers, but I do not know what the difference(s) may be
Thanks for the response! Yes they're for sure different parts. I did reach out to Takase-San from Samurider and he was not able to offer additional info in terms of fit Sad
02-06-2019, 01:50 AM
New Mexico
Threads: 33
Likes Given: 6
Not seeing any discernible difference in the parts sketches.
Is it possible that the key type is the only difference?
Does 2017 have the laser cut type of key?
02-06-2019, 02:17 AM
pekingduck Offline
Southern California
Threads: 41
Likes Given: 39
Starting around 2015-2016, many Hondas went to the wave-cut or laser-cut style key. Africa Twins, CBR650F, VFR1200, CBR500R and CB1100. So the question becomes, will the ignition switch of a 2017 fit earlier models?
I should add that if you are ordering the 2017 switch set, the helmet/seat locks will not interchange, so you'd still have to carry a separate key.
02-06-2019, 04:58 AM
(02-06-2019, 02:17 AM)SportsterDoc_imp Wrote: Not seeing any discernible difference in the parts sketches.
I think the housings are different. But what about the tumbler inside?
02-06-2019, 06:14 AM
Houtman_imp Offline
Threads: 115
It will be cheaper and easier to just use two different keys.
02-06-2019, 09:20 AM
New Mexico
Threads: 33
Likes Given: 6
Side by side very helpful!
02-06-2019, 09:55 AM
peterbaron Offline
Likes Given: 996
(02-06-2019, 01:33 AM)cb1100_dude_imp Wrote: Hello,
Thank you!
L
From the pics of '13 & '17, blank keys look different and have different part numbers. You may want to talk to your local locksmith and show him both key$.
He will have to play with pin tumblers and deal with : ignition cylinder, gas cap and seat lock, some limitations apply.
In automotive business, we use locksmith skills to fit an old key with new ignition switch ass-y/locks, so the customer still has the original keys that operate all locks/ign. switch ass-y...
Slim chance if the keys are different, check.
02-06-2019, 12:15 PM
pekingduck Offline
Southern California
Threads: 41
Likes Given: 39
Keys are different.
02-06-2019, 12:45 PM
  2014 Ignition Key tomcat_imp 37 2,571 10-02-2023, 05:36 PM
Last Post: The Gecko_imp
  Wire colors not matching the diagram (2013 A / 2017 NA)? LayerCake_imp 16 1,296 05-30-2022, 05:45 AM
Last Post: LayerCake_imp
  Ignition switch live accessory wire? ozigoo 10 862 02-18-2021, 02:32 PM
Last Post: ozigoo
  new batterie and Boost emergency starter Houtman_imp 11 829 09-13-2020, 06:31 AM
  2017 Gas Tank on a 2013? chandler_imp 67 4,025 06-21-2018, 04:47 PM
Last Post: Jurlie_imp
