Wire colors not matching the diagram (2013 A / 2017 NA)?
LayerCake_imp Offline
Threads: 5
I'm planning to add a smart turn system and smart brake module to my 2017 CB 1100 NA/RS as a no cut mod.
I stumbled across a wiring diagram for the 2013 and later CB 1100 A.
Is there a difference in the wiring colors for the 2017 since it has LEDs?
The diagram worked fine for other things like the option plug that I'll use to attach the brake module but for the indicator switch it's pretty different even the number of wires does not match.
05-27-2022, 09:21 PM
Likes Given: 1,015
RE: Wire colors not matching the diagram (2013 A / 2017 NA)?
Were the 2014 std bike’s turn signals LED? If so, try [url=http://cb1100forum.com/forum/showthread.php?tid=13353]here.
05-27-2022, 09:45 PM
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Given: 142
No Cormanus. The 2014 lights are not LED.
05-27-2022, 10:41 PM
Threads: 5
(05-27-2022, 09:45 PM)Cormanus_imp Wrote: Were the 2014 std bike’s turn signals LED? If so, try [url=http://cb1100forum.com/forum/showthread.php?tid=13353]here.
Thanks for that link. It seems none of those match what's on my bike. Either they went another way in the 2017 models or a previous owner changed a bunch of things. The strangest thing to me is that one of the black 6 pin mini connectors only has four pins populated.
05-27-2022, 10:43 PM
peterbaron Offline
Likes Given: 996
RS has LED turn signals
05-28-2022, 09:41 AM
Threads: 5
Yeah I just don't have the correct wiring diagram.
05-29-2022, 12:24 AM
I wonder if [url=http://cb1100forum.com/forum/member.php?action=profile&uid=3454]PB has a reference?
05-29-2022, 01:41 AM
peterbaron Offline
Likes Given: 996
The 2017 does not have LED either, at least in Canada… unless I am wrong.
What particular MY diagrams you need?
Reading from my memory, as I am a few hundred kms away, there are two wires to rear turn signals and three to the front, as it has frt running lights..?
I have smart LED brake/ running light module mounted on my helmet and transferable to my other one… two clicks and changed helmets.
Got way too many automotive diagrams in my head… and sometimes people say: sir, you have a wire sticking out from your head..Big Grin
05-29-2022, 01:44 AM
Likes Given: 1,015
Sir, you have a wire … oh, never mind. Tongue
05-29-2022, 07:00 AM
peterbaron Offline
Likes Given: 996
(05-29-2022, 12:24 AM)LayerCake_imp Wrote: Yeah I just don't have the correct wiring diagram.
PM sent, hope these work for you, so you can finish your project.
05-29-2022, 07:07 AM
  Ignition Starter 2017 on 2013 Bike cb1100_dude_imp 24 1,661 08-22-2021, 12:35 AM
Last Post: domeular_imp
  Ignition switch live accessory wire? ozigoo 10 888 02-18-2021, 02:32 PM
Last Post: ozigoo
  Wire Wheel / Cast Wheel Swap pekingduck 37 2,614 06-05-2020, 12:35 PM
Last Post: michael1954
  3-wire to Connector for Brake Light for Custom Fender Eliminator x(why)z_imp 5 516 02-05-2019, 12:40 PM
  2017 Gas Tank on a 2013? chandler_imp 67 4,341 06-21-2018, 04:47 PM
Last Post: Jurlie_imp
  wire spoke wheels jim rosenthal_imp 57 3,388 05-05-2018, 09:18 AM
Last Post: FLYTYM_imp
  Matching helmet/Shoei NeoTec review Papa Weeley_imp 17 1,222 10-20-2015, 09:21 AM
Last Post: Desert viper_imp
  Matching bucket and chrome instrument cups...Perfection the Ferret 37 2,036 02-01-2015, 09:48 AM
Last Post: furious_blue_imp
  Spark plug wire colors? AllenM_imp 1 221 09-05-2013, 06:53 AM
Last Post: HondaJon_imp
  Different colors ....black, silver, white OEM tanks RajunCajun_imp 1 211 06-28-2013, 06:46 AM
Last Post: Ack-CB11_imp
