Choice of Fog /Accessory Lights
Ennsync_imp Offline
Threads: 13
I have strong LED lights and accessory lights on my 2 other bikes.
2014 VFR has factory LED and brighten the road as you do not need any additional . My VStrom has LED Bulbs and I installed two additional Fog lights , so bright as day.
CB uses no LED and seems to be not bright either at day or night .
Plan is to change the bulb to DOT approved LED and ad 2 accessory lights or Fog lights .Biker
What would be your recommendations for lights and place to install( I a have SW Motech crash guards installed very low)Thanks
Thank you
Ride safe/Ride Long
10-10-2018, 05:27 AM
pekingduck Offline
Southern California
Threads: 41
Likes Given: 39
RE: Choice of Fog /Accessory Lights
I think driving lights work best when mounted as high as possible, pointing down ahead. Lights that are eye-level reflect the most light back at your eyes, as seen on most P-D bikes. I've ridden off road with super-brite helmet-mounted LED lights, and they are the just phenomenal. (Just remember not to look at anyone directly.)
Long-range, low-mounted driving lights are not very effective (except in blinding others), since they are aimed upward.
On cars at least, I've found foglights to be ineffective, even if they are mounted low, with yellow lenses, unless you can turn your headlights off. The headlights will blind you, but at least others know there's someone there. If I get caught in fog, I swivel the headlight down and just go slow.
10-10-2018, 06:31 AM
AzBob_imp Offline
Threads: 6
I have Clearwater Glendas mounted on my SW Motech bars.
https://www.clearwaterlights.com/collect...5916097157
10-10-2018, 08:37 AM
jedd_imp Offline
Threads: 27
My vote is the Denali lights. Twisted throttle has a couple videos on this light
THis video shows how they attached them to CB1100 sw motech crash guard
Go to the 2 min, 10 sec mark :
This video shows different lens to setup the denali for fog light use,
Go to the 1 min, 50 sec
10-11-2018, 08:09 AM
Ennsync_imp Offline
Threads: 13
Great video , thank you
Ride safe/Ride long
10-12-2018, 01:53 AM
Ennsync_imp Offline
Threads: 13
Good video each time you watch it
10-16-2018, 05:20 AM
  2017 OEM CB1100EX/RS Accessory Brochure rdprdp01 0 330 04-16-2025, 02:05 AM
Last Post: rdprdp01
  Additional front driving lights Davidjill_imp 6 643 08-28-2024, 12:46 PM
Last Post: michael1954
  16,000 Lumens Spot Lights to complement 2017 Led headlights 17-CB-002 51 4,232 04-23-2024, 07:31 AM
  Accessory Removal Wagonpeddler_imp 13 964 03-22-2022, 05:22 AM
Last Post: Wagonpeddler_imp
  Where to mount auxiliary lights Gone in 60 42 2,517 04-20-2021, 09:17 PM
  Ignition switch live accessory wire? ozigoo 10 865 02-18-2021, 02:32 PM
Last Post: ozigoo
  2017 CB1100EX Clearwater Darla Lights Install TXBikerGuy 7 634 07-25-2020, 08:51 AM
Last Post: TXBikerGuy
  Advice on aux Brake lights. hawk123_imp 6 751 08-18-2019, 04:03 AM
Last Post: hawk123_imp
  amber LED fog lights Chuckk_imp 14 1,295 06-20-2019, 01:46 AM
  Accessory connector inside headlight bucket 17-CB-002 4 424 10-29-2018, 02:36 AM
Last Post: 17-CB-002
