06-09-2013, 06:28 AM
Does anyone know the color of the wire {hot} going to the rear brake? I have some LEDs on a hard box mounted on the luggage rack and want to wire them in.
Thanks
Thanks
wire color
Thanks
06-09-2013, 07:30 AM
(06-09-2013, 06:28 AM)gcarper_imp Wrote: Does anyone know the color of the wire {hot} going to the rear brake? I have some LEDs on a hard box mounted on the luggage rack and want to wire them in. There are 3 wires going to the light bulb. G/Y goes to the brake switches 12v when brake switch activated. Bl/Br(black/brown) 12v when ignition switch is on G (green) tied to ground (chassis lug) You should disconnect the 3P connector and verify this. I used the wiring diagram, but you should not trust the internet
« Next Oldest | Next Newest »
| m-txd/rxd wire (white) ecu to instruments communication | deano | 28 | 1,816 |
01-23-2026, 12:48 PM Last Post: pekingduck |
| M-TXD/RXD wire is disconnected | deano | 1 | 200 |
01-01-2026, 06:40 AM Last Post: Cormanus |
| Wire Colors for Signals, Tail Light | RedRoevr_imp | 10 | 775 |
05-01-2022, 06:23 AM Last Post: Charlie Bravo_imp |
| 2017 EX Tail light wire channel access | TXBikerGuy | 8 | 784 |
07-26-2020, 06:57 AM Last Post: TXBikerGuy |
| Theft Attempt - Cut Wire | ishouldbuyatacotruck_imp | 17 | 1,370 |
07-05-2019, 04:34 PM Last Post: Guth_imp |
| Trigger wire under seat for fuzeblock | Jeya_imp | 14 | 969 |
08-17-2017, 03:54 AM Last Post: Lord Popgun |
| anyones nuts turning bronze color | ss2wheels_imp | 20 | 1,389 |
09-11-2016, 02:54 AM Last Post: BestStandard_imp |
| Which wire to tap for GPS power? | Inhouse Bob | 32 | 2,241 |
07-19-2016, 07:32 PM Last Post: Cormanus |
| Paint Color Code & more | rbike_imp | 3 | 445 |
02-19-2016, 11:29 AM Last Post: Ferrealls_imp |
