Threads: 3
Hi guys, im new to this forum and i recently collected my 2017 CB1100RS. Does anybody know where i can tap switched power for the trigger wire on my fuzeblock? I intend to use my fuzeblock to power a tyre pump and usb charger.
Cheers,
Jey
Likes Received: 649 in 287 posts
Likes Given: 804
Howdy Jeya and welcome to the forum. Can't help you with your issue, but undoubtedly someone will be along shortly who can.
Threads: 3
Cool thanks. I'll continue probing around the bike and let you guys know if i have found anything.
Threads: 16
I added a fuzeblock to my VStrom, tapped into the tail light wire for the switched power.
Threads: 3
(08-15-2017, 10:55 PM)hb9400_imp Wrote: I added a fuzeblock to my VStrom, tapped into the tail light wire for the switched power.
Yep i think that is also one way just wondering if anybody knows which color wire that wld be on my bike
Likes Given: 804
don't know where the wiring wizards are hiding but i believe there are connections in the headlight and under one of the covers for power.
Popgun?
Threads: 6
Get a cheap test light, the kind with the pointy end and poke away at the wires at the rear while the tail light is on.
I did this too, but don't remember what wire it was and it was a 2013 CB anyway. I know it's in the various repair manuals that have the wiring schematics in the back.
Likes Given: 804
this thread may help
http://cb1100forum.com/forum/showthread....hlight=red
I know someone just posted pics of the connector but I can't find them right off hand
Threads: 6
I also recall from other threads that different countries have different wiring set ups. Like when discussing who has turn signals always on.
Likes Given: 143
Ferret, I didn't respond as I don't have a wiring diagram for an RS, AND, what Classic says is true. For instance, one of our members in Moscow and I found out they do not have an accessory connector in the boot by the battery.
Here is a pic of the accessory connector in the headlight shell. Its the red connector at the bottom. I don't know why these are still showing as they are on Photobucket.
http://cb1100forum.com/forum/showthread....9#pid87099
I can look at the diagram for colors, but green is ground on our bikes.
Ok, on the diagram, the brake/tail light has 3 wires. Green is ground, green/yellow is brake, and Black/brown is tail light (on all the time).
The Black/Brown wire is connected to the 10amp Meter/Ilumi fuse. So are the accessory connectors.
