Electrical / GPS
I am planning to install a GPS and found a spare wire in the harness (red connector with a black cap) next to the battery but not sure where I could get the connector for it or if someone has a idea where I could tap power for the GPS
I believe that may be reserved for the heated grips sub harness.
Or a diagnostic connector? Ill see if I can find it on the wiring diagram later.
I run the GPS on my ST thru the connecter on my battery tender
Its not the diag. connector (DLC). That one has 4 wires and is behind the left side panel.
Looking at the cable layout drawing shows there are 2 option connectors. One is in the headlight shell and the other is by the battery in a connector boot.
The connectors are labeled in the book as "OPTION 2P (Red) CONNECTOR.
Hope that helps!
(05-12-2013, 01:43 AM)Lord Popgun_imp Wrote: Its not the diag. connector (DLC). That one has 4 wires and is behind the left side panel.
Hope that helps!
Popgun, does that optional red headlight connector have a brown/black and a green wire gng to it? Trying to pick up 12 volts without running wires back to battery for cig/accessory adapter.
I am not by my manual, but I believe that is the color scheme. Its the only unused connector in there and has a cap or plug or whatever for protection. I'll check the diagram when I get home.
(06-13-2013, 03:23 AM)Lord Popgun_imp Wrote: I am not by my manual, but I believe that is the color scheme. Its the only unused connector in there and has a cap or plug or whatever for protection. I'll check the diagram when I get home.
Ok, thanks. I'm having trouble getting the red cap off to take a voltage reading. 3 little dimples apparently need to be depressed to remove cap.
Ok, thats it.
Green is ground and black/brown is hot.
(06-13-2013, 08:22 AM)Lord Popgun_imp Wrote: Ok, thats it.
Thanks for the help.
   Light problems/electrical Dude_imp 6 522 09-13-2023, 07:21 PM
Last Post: Dude_imp
  Looking for OEM electrical terminals/connectors. FLYTYM_imp 2 277 07-14-2021, 01:13 AM
Last Post: FLYTYM_imp
  Electrical problem maybe? Cormanus 37 2,168 05-25-2020, 08:19 AM
  electrical power pick up andyoz_imp 6 577 11-19-2019, 10:17 AM
  Electrical Gremlin - Clock/Trip Reset & No Blinkers johnf514_imp 10 720 03-23-2018, 04:16 AM
Last Post: max
  Electrical Drawings CB1100NA (RS 2017) piantellik_imp 7 556 09-15-2017, 01:26 PM
  Electrical plug contact cleaning and maintenance curlyjoe 6 519 01-21-2017, 06:14 AM
   Complete Electrical Failure Ulvetanna_imp 21 1,425 10-24-2016, 12:43 PM
Last Post: Ulvetanna_imp
  Help identifying electrical connector postoak_imp 8 450 08-13-2016, 02:09 AM
Last Post: postoak_imp
  HELP - URGENT! Electrical Question? beardyweirdy@me.com_imp 6 428 11-13-2014, 11:19 AM
Last Post: thessler3_imp
