size of rear axel head and nut
I can't seem to find what size socket/wrench I'll need for the rear axle. I have an adjustable wrench but it's not metric Angel but I'd rather get the corrected sized tools.
Anybody here know?
Check doing 600 mile service in how to. Pretty sure I put it on there. Looks like 32 mm on one side, 27 mm on other side, but Ive only needed the 32 since Ive never removed the wheel
OOOh! Dang, I forgot about that little section. Worship
My 1 1/4 socket fits the nut on the rear axle real good.
I have a 27mm box end wrench for the other side so I should be golden when it comes time for anew tire.
Rear wheel :
r/s axle nut..... 32 mm. ( 1 1/4" will fit)
l/s axle nut .... 27 mm
Chain adjuster bolts......8 mm
From the section our friendly neighborhood Ferret. And a tip of the cap to Ole to!
Quote:I have an adjustable wrench but it's not metric
I do read these posts even if I don't always reply. My adjustable wrench works on both metric and SAE nuts. Big Grin
You must buy the better quality line of tools then. Worship
Big Grin
(01-02-2014, 04:18 AM)Rboe_imp Wrote: You must buy the better quality line of tools then. Worship
Big Grin
Isn't when it is laying on one side it is standard, and when you flip it over it is on the metric side?
Beer
All of mine work for either standard or metric, I just flip it over in my hand when I want to use it on the other type...
This is a great forum! I learn so much here that I almost save the amount I spend on farkles that I've seen posted here. Almost!Angel
  What is the Correct Chain Size for a 2014 Model? chync_imp 12 1,153 02-28-2023, 01:16 AM
Last Post: Maturecheese_imp
  Brake reservoir screw head issue satchit 72 5,339 04-24-2022, 11:55 PM
  Chrome cylinder head cap Juancho76_imp 21 1,619 04-03-2022, 08:48 AM
Last Post: Juancho76_imp
  2013 versus 2014 wheel size Houtman_imp 19 1,600 10-08-2021, 05:11 AM
  Cams, Compression, Head Work? boynton6spd_imp 12 963 08-08-2021, 02:27 AM
Last Post: old blue_imp
  Regina HPE chain-kit - looking forward to these coming in our size. Tev62 13 1,067 04-20-2021, 06:45 AM
  CB900 Custom oil stopper on valve head AOrhun_imp 9 791 01-27-2021, 10:06 PM
  Fork Tube hex head bolt tool fitment ? bflint 8 707 11-30-2020, 06:24 PM
Last Post: jtopiso_imp
  Oil Drain Plug Washer Size Tev62 14 1,068 11-18-2020, 06:29 PM
  Cylinder Head cover oil leak and valve clearance increase. zirconxi_imp 6 645 09-01-2020, 12:19 AM
