Nail in rear tire.
Can this nail in my rear tire be safely repaired or must I replace the tire?
If it can be repaired , what do I need exactly.
Thanks for your help? Jim[Image: 6a5ecea4efa2671bc279c7f61e280e66.jpg]
Crashing is simply an opportunity to upgrade. Posted using Tapatalk.
There are strong opinions on both sides of this, but to me with a moto tire I would replace it. You can repair it as a stop gap solution until you get a new tire, but I wouldn't leave it there. These are radial tires and as such you now have a damaged steel belt that is more prone to failure due to the damage. I just can't justify the risk. You can get a new tire for about $125 + mounting and that's a steal compared to risking your life and having a tire fail unexpectedly be it a blow out or just the belt shifting on you while either at highway speed or worse going at it hard in the twisties and causing you to either low side or high side.
My $.02
I had a flat in my rear tire at 364 miles and felt the same as the previous post. Replace the tire .
Tires are cheap compared with hospital bills, why take the risk.
I got a nail in mine last year with around 300 or so miles. This was when the tires were on backorder. I plugged it until the tire came it, but haven't mounted it yet. It has 1300 miles with the plug, but all at 45-50mph. For a highway trip, I'd have it changed.
Not getting into the change/plug wars. Bad as the oil wars!
I'd like to just get it to the dealer 13 miles away.
Since this is a nail and near the center tread, I would dismount the tire and patch it from the inside. Most dealers will not do this because of the reasons already stated. I would do the repair myself and use the zip tie method to remount.
Or I would use this as an excuse to buy a set of Pilot Road 3 Michelins.
(07-06-2014, 10:11 AM)meowguy_imp Wrote: I'd like to just get it to the dealer 13 miles away.
I've plugged tires just so I could get the bike to service. I echo others who would not choose to do any more than that on a compromised tire.
^If you're only trying to get to the dealer, no need to dismount the tire. Either push a gum plug into it, or, if you're feeling really anxious, just push the nail all the way in and be on your way.
Either method will gladly give you the 13 miles you're looking for, and much more if needed.
Good: Mushroom plug would probably work fine on that one. Skinny nail, not that bad.
Better: Or a patch on the inside. Easy. But, if you have any lack of confidence regarding either of those, Best: a new tire Smile
I had mine catch a nail near the center on the rear tire with low miles. I have always patched my own tire from the inside with a large patch from Slime Patch kit. Leave it over night to fully cure but normally cures in a couple of hours. Now, they have tire patch kits that are a combination of a plug and patch type & those are by far the best alternative in terms of the type of patch but in the end it is how comfortable you are with a fix. If you have the Bridgestoneb54's that tire is so beefy stiff that it was so hard for me to dismount with just tire irons.
  Rear only tire on the front? mattmcuomo@yahoo.com 5 571 10-09-2023, 06:05 AM
  Tire replacement - Not a "Tire Thread" SportsterDoc 12 940 07-18-2018, 06:50 AM
Last Post: SportsterDoc
  New Rear Tire and Rear Brake Pads memphismike_imp 5 524 06-11-2018, 09:35 PM
  Do I have to remove the rear tire to remove the fender? Nemo_imp 3 340 03-21-2016, 12:11 PM
Last Post: uscgmac_imp
  Rear tire replacement H.Ibsen_imp 13 899 10-08-2015, 12:34 PM
Last Post: H.Ibsen_imp
  Rear Tire Time, 14K HikerToo_imp 18 1,306 07-28-2015, 11:03 AM
Last Post: flynrider
  Rear tire on the front gcarper_imp 13 817 11-24-2014, 12:26 PM
Last Post: Guth_imp
   Need help/advice regarding removing the rear wheel/tire p-man_imp 16 1,095 05-07-2014, 01:15 PM
  My original rear tire. Randy B 4 393 02-16-2014, 12:22 PM
Last Post: Randy B
   Bridgestone BT45 Bias-Ply 150/70 rear tire Red Mist_imp 20 1,558 02-11-2014, 01:03 PM
Last Post: Red Mist_imp
