 Bridgestone BT45 Bias-Ply 150/70 rear tire
This thread was initially posted to talk about how much I like the BT45's with the 150/70 rear. I still do, but there was a concern I had regarding tire clearance.
This seems to be resolved and I can't determine that there is any lack of clearance. Marks on the tire were apparently from some other cause.
The combination works very well, I like the handling better with the beefier rear tire with more available sidewall. Overall gearing also goes up a little, so your fuel mileage will improve a little over the stock tire. Acceleration doesn't seem to be affected noticeably.
As with anything, departure from stock can cause anomalies. The rest of this thread explains the situation.
YMMV
Great info, Thanks
I'm on my 3rd set of BT-45s on my CB750 (which specifies bias tires). I think they are an excellent "all around" tire. There are stickier tires, but I've never had an issue scraping pegs on the 750. They also wear quite well.
My CB1100 came with the BT-54s from the factory. I had heard from sources that they would be available in the U.S. in early 2014. I see by a quick look on the web that they seem to be generally available in Europe and the U.K., but not in the U.S. Huh
The BT-54 seems to be Bridgestone's radial equivalent of the BT-45. I've been satisfied with the performance of the BT-54s so far (just over 3K miles). I'm hoping that they'll be more widely available by the time I need a new set of tires for the CB11. If not, it's nice to know that the BT-45s will work.
(02-07-2014, 03:29 AM)Red Mist_imp Wrote: This thread was initially posted to talk about how much I like the BT45's with the 150/70 rear. I still do, but there was a concern I had regarding tire clearance.
YMMV
I have the Bridgestones from the factory with almost exactly the same miles. I don't see any weirdness with the tires; I'm not sure what you mean by cupping? Were your tires under-inflated by any chance? The recommended pressure is quite high (42 psi if memory serves).
Quote:, and the rear was not quite wide enough to match the lean angle available from the front.
That's the way every motorcycle I've ever seen is. As long as the rear tire is wider, the front will not come close to it's maximum lean angle. It's just not physically possible. The difference on my CBR is almost comical. Quite frankly, I don't want the front tire anywhere near its limit. The rear can loose a bit of traction and its recoverable. The front, not so much.
BT54's are readily available stateside; check out http://motorcycle.chaparral-racing.com/search?w=bt54, among others. Prices are quite good, too. You're just limited to the stock sizes.
YMMV
That's the way every motorcycle I've ever seen is. As long as the rear tire is wider, the front will not come close to it's maximum lean angle. It's just not physically possible. The difference on my CBR is almost comical. Quite frankly, I don't want the front tire anywhere near its limit. The rear can loose a bit of traction and its recoverable. The front, not so much. I think the Dunlops may be more prone to cupping; I was hoping to use the Bridgestone radials to compare but the lack of the 150/70 over here got me to try the BT45. No tire pressure issues; I check pressure before every ride and have an air compressor and receiver in my garage, so no excuses not to have them exactly right before every ride. Always ran 36 psi front.
It is physically possible to use more of the front than with aggressive trail braking at lean, especially at track or supersport tire pressure settings; under heavy braking the front tire's contact patch can double in size whilst straight up and can still get grow enough during deep cornering/braking to compress the sides of the front tire to very close to the edge. Supersport tires vary quite a bit with some front tires falling off almost to vertical, but under heavy braking/cornering loads this will flatten out a great deal.
Riding style, tire pressure, brand of tire, all of it figures in.
(02-07-2014, 09:12 AM)Red Mist_imp Wrote: BT54's are readily available stateside; check out http://motorcycle.chaparral-racing.com/search?w=bt54, among others. Prices are quite good, too. You're just limited to the stock sizes.
YMMV
Thanks! I'd done a Google search for the stock sizes and all I came up with was U.K. sites.
I did a test to see if I could cause the tire to contact the inner fender where I suspected it had done so in the first place. I set the suspension to the softest position, marked the area I thought was causing interference with a black marker, and rode the bike on my local rough test road. Considering the suspension was set to its softest, I figured it would bottom out and create the issue if it was still present after my field engineering efforts (with a hammer) to create a couple of additional millimeters of clearance.
I saw no indication at all of any kind of contact. It may be that my modification worked, or that the marks were made while the tire was being installed and I just missed them (and they were coincidentally aligned exactly with the inner fender protrusion), or that high speeds with commensurate diameter expansion are necessary to replicate the issue.
Either way I am going to monitor but do not recommend any other size but stock.
We used to see the same problem mounting certain front tires back in the days when things weren't quite standardized; I recall my VFR750F burned a groove in the underside of the front fender when fitting the Metzeler Comp K Laser tire, after being ridden at high speeds. This was not really too unusual.
If the suspension travel is in fact 3.5" then there is no way the 150/70 tire could possibly contact any part of the fender. Perhaps the groove running down part of the center of the tire was caused by the mounting process or something else is amiss.
Anyone else out there try any other tires but what came on the bike stock? Here again, based on the suspension travel, the fitment of the 150/70 should have been absolutely fine.
I see there are about a thousand forum members here; somebody's got to know something...
(02-07-2014, 03:01 PM)Red Mist_imp Wrote: If the suspension travel is in fact 3.5" then there is no way the 150/70 tire could possibly contact any part of the fender. Perhaps the groove running down part of the center of the tire was caused by the mounting process or something else is amiss.
Seems a bit odd without seeing it but I have had a 150 rear since day one for a total of 8500 kms no problems heap of clearance
How come problems with funny noises, wind buffeting, vibrations, etc always happen "at speed"? Why can't we ever know what the speed actually is? How fast is at speed anyway?
regarding marks on the fender, why would someone lift a wheel 3.5 inches too high when putting the wheel on. And if they did, how would that leave a mark? What about marks on the tire?
and if black marks on the fender come from the tire and you put a black marking pen on the spot to see if the tire rubs and leaves a black spot, what's that going to tell you when either way you're looking at a black spot?
and are the shocks bottoming out or not?
  Bridgestone T33 series tires 17-CB-002 4 428 04-12-2026, 01:44 PM
Last Post: 17-CB-002
  Rear only tire on the front? mattmcuomo@yahoo.com 5 579 10-09-2023, 06:05 AM
   Rear brake pedal Mixagon_imp 28 2,135 08-06-2022, 07:29 PM
Last Post: Mixagon_imp
  Bias Ply vs Radial bigsheep_imp 24 1,845 10-24-2019, 12:24 AM
Last Post: bigsheep_imp
  BT45 Tyre Behaviour Haggard Rider_imp 45 2,876 02-01-2019, 09:46 AM
Last Post: jimgl3_imp
  Tire replacement - Not a "Tire Thread" SportsterDoc 12 940 07-18-2018, 06:50 AM
Last Post: SportsterDoc
  New Rear Tire and Rear Brake Pads memphismike_imp 5 529 06-11-2018, 09:35 PM
  Do I have to remove the rear tire to remove the fender? Nemo_imp 3 343 03-21-2016, 12:11 PM
Last Post: uscgmac_imp
   Tire inflator, compressor: questions... quietguy_imp 35 2,505 01-11-2016, 07:57 AM
Last Post: quietguy_imp
  Bridgestone t30 front tire review Motogeezer1949_imp 1 323 12-10-2015, 12:47 PM
Last Post: the_undecider_imp
