Rear tire on the front
I want to put a tire labeled rear on the front. Why? Well I've been running the trails through the national forests around here and while my Avon Road riders are OK thought I'd put on some adventure labeled tires. Problem is there are only a few front tires that will fit 18inch rims and they require a tube. Tires in the 120x18 size for rear usage do not require tubes. I seem to remember that the rotation had to be reversed. Right?
thanks
No idea. But I eagerly await the results of your experiment.
If you must run a rear ,yes mount it backwards and don't ride it on the street. If you run a tube try and run at least 20 psi so you don't rip the stem off when stop hard.
This is exactly why Honda needs to release the CL1100 Scrambler. Biker
Sorry, but I couldn't resist — hopefully some answers that are actually helpful will follow.
Oh gawd, the Paris Dakar CB1100. Angel
(11-24-2014, 03:04 AM)Rboe_imp Wrote: Oh gawd, the Paris Dakar CB1100. Angel
Or the Afrikan Inline!
Can't wait to see the "beak" it will have.
(11-24-2014, 04:41 AM)redbirds_imp Wrote: Can't wait to see the "beak" it will have.
sorry no beak and uuummm CL? maybe I can get some high pipes made up------------------
(11-24-2014, 01:43 AM)metallyguitarded_imp Wrote: No idea. But I eagerly await the results of your experiment.
+1
There's already a beautiful Scrambler available. And it's made by Triumph. Wink
  Rear only tire on the front? mattmcuomo@yahoo.com 5 579 10-09-2023, 06:05 AM
  How To :19 tooth front, and now, a 37 tooth rear sprocket on 2013 pekingduck 60 3,963 03-07-2021, 09:32 PM
  Too much weight to balance front tire? thebrawnyman_imp 11 957 09-11-2019, 09:37 PM
  16 front 45 rear sprockets jermo47_imp 24 1,667 06-09-2019, 12:17 PM
Last Post: 17-CB-002
  Bike fell over, broke the front brake lever and bent the rear brake jlouis976_imp 24 1,600 09-14-2018, 12:35 AM
  Deciding 37 vs 35 tooth rear sprocket on 2013, 19 on Front is correct rbike_imp 41 2,725 09-01-2018, 03:19 AM
Last Post: IndianRider_imp
  Tire replacement - Not a "Tire Thread" SportsterDoc 12 940 07-18-2018, 06:50 AM
Last Post: SportsterDoc
  New Rear Tire and Rear Brake Pads memphismike_imp 5 528 06-11-2018, 09:35 PM
  Front tire replacement LongRanger_imp 6 500 06-19-2017, 12:07 PM
Last Post: Randy B
  Cupping front tire White Dog_imp 12 668 06-18-2017, 03:34 AM
Last Post: Doug_imp
