Rear tire replacement
I have been on my recent purchase of a 2013 CB 1100/ABS for about 2 months and 1000 miles. The rear tire, Dunlop Sportmaster 140/70-18 has a screw in it and needs to be replaced. The front is nearly new. I'm having trouble finding it. Any suggestions?
Thanks!
Mine came with the BT-54 radials, have bought them from these guys last 2 times.
http://www.chaparral-racing.com/product/...-0371.aspx
The dealer, or a place like this: http://www.partsfish.com/oemparts/a/hon/...rear-wheel
This one is cheaper: http://www.procaliber.com/oemparts/a/hon...rear-wheel
Here is another: http://www.hondabikes.com/fiche_section_...veh=242920
That's all I got.
Does it 100 percent need replacement? I've plugged motorcycle tires before and had them successfully last the normal life of the tire.
I plugged my rear tire at 300 miles and its still good at 2750. No, I don't ride as much as some of you guys.
I bought Bridgestone BT54s in stock sizes at denniskirk.com Good prices and fast delivery. Put them on the bike myself!
https://www.denniskirk.com/tires/2013-honda-cb1100.mmy
Just as a safety note I would never plug a motorcycle tire except in a pinch until I could get a new tire. Tires for this bike are cheap and easy to replace
You only have one life the way I ride a blow out at high speed could be catastrophic. Also last time i ordered tires from Dennis's Kirk I had them in 2 days literally it was a great buying experience.
(10-07-2015, 12:50 PM)Brookland27_imp Wrote: Just as a safety note I would never plug a motorcycle tire except in a pinch until I could get a new tire. Tires for this bike are cheap and easy to replace
I agree with this, but I will say this about the factory Bridgestones....
I hit a piece of broken concrete that was in the middle of the freeway at 75mph and blew out my front tire....and didn't realize it was flat. The steering got a bit heavy so I knew something was up, but I never lost control of the bike or felt unsafe. I didn't know it was actually flat until I got off the freeway....20 or so miles later. Yeah, I probably should have stopped, but being on the side of the freeway in pre-dawn light on SF bay area roads is not my idea of a safe place to be, so I kept going.
Amazingly there was no damage to the inside of the tire that I would have expected to see from riding on a flat tire, only the hole from the initial puncture.
I in no way would recommend doing this, but I really had no idea the tire was flat, and this just speaks volumes to me about the quality of the tire that Bridgestone created for this bike.
Here is a map of how far I rode.
[Image: 0fde9ce4b96c4c9a0fae70ced8e7b70d.jpg]
Using a mushroom type plug is fine, as long as there's no cord damage.
  CB1300 headlight bucket replacement spechg 5 369 03-16-2026, 10:12 AM
  HISS Key replacement UK Davidjill_imp 12 962 01-19-2026, 05:09 AM
  Rear brake pad replacement LongRanger_imp 39 3,468 05-03-2025, 10:45 AM
Last Post: Delphisa
  New speed meter replacement ACE_IRA_imp 3 518 02-13-2025, 06:25 AM
  Rear only tire on the front? mattmcuomo@yahoo.com 5 573 10-09-2023, 06:05 AM
  Fork Pipe replacement suggestions danieljrmurray_imp 3 475 10-09-2023, 02:31 AM
Last Post: danieljrmurray_imp
  Fuel filter replacement Mafd2_imp 36 2,830 02-11-2023, 01:54 AM
  Replacement Battery dave 54 3,880 02-04-2023, 12:41 PM
  2013 replacement wheel Randy B 8 764 11-13-2022, 10:32 AM
Last Post: Randy B
  Clutch replacement advice misterprofessionality 31 2,393 06-11-2022, 05:51 PM
