Threads: 183
The front disk brakes on the non-ABS model use five 6mm x 18mm Torex bolts. I want to remove the bolts to pull the collars and paint the collars gold - or find someone that will anodyze them.
Any suggestions for finding a 6mm Torex wrench? I'm reluctant to use a Torex bit. I think the bolts will require some force to remove and I'd like a solid one piece wrench - think hex wrenches. I don't want to bugger them up.
I've found torex wrench sets but they are on the pricy side and all I'll ever need is a 6mm Torx.
I tried some auto supply dealers, no luck.
Thanks in advance for your help
Likes Received: 576 in 259 posts
Likes Given: 756
did you try sears if not them try McMaster-Carr
http://www.mcmaster.com/#torx-keys/=t8l2e5
Threads: 1
(08-11-2014, 07:42 AM)CB4ME_imp Wrote: The front disk brakes on the non-ABS model use five 6mm x 18mm Torex bolts. I want to remove the bolts to pull the collars and paint the collars gold - or find someone that will anodyze them.
I've used this type with a socket wrench. I know this qualifies as a "bit" but it is permanently embedded in the socket.
http://www.homedepot.com/p/Husky-T30-3-8.../202913546
Threads: 115
Have you tried NAPA stores ?
Other wise Google the size and some supplier will just sell that size but the shipping could perhaps cost more than just buying a set locally.
Threads: 6
You can get the Craftsman torx sockets at Sears, but unfortunately you have to buy the whole set...that's what I had to do a few years back
Threads: 19
They come off fairly easy. Go to Harbor f. or Walmart. The size you will be using will be a 3/8 drive. easy, Easy.. Jayimpalaman
Threads: 8
Torx socket is a T30 and recommended torque is 15lb/ft which is not going to require a huge amount of effort to undo. Over the years I have bought Koken seperately at no great cost.
Threads: 183
Thanks everyone! Great information. Order placed with McMaster-Carr
Threads: 115
An other good place to buy individual sockets etc. etc. is
MSC Industrial Supply. mscdirect.com
I have bought many "odd" size sockets from them and you can pick the quality you want.
I bought many Pronto sockets and happy with the quality of them.
Threads: 18
Likes Received: 5 in 3 posts
Likes Given: 1
I put my torx bits in a 1/4" socket
works great
