02-01-2015, 05:52 AM
I'm curious how many CBs actually needed a valve adjustment at 8k.
Valve Check Poll
02-01-2015, 03:41 PM
Not mine.
02-04-2015, 10:58 PM
Mine still didn't need it at 24,000 miles.
02-05-2015, 02:52 AM
Nope. Mine was adjusted at 18,000.
02-07-2015, 03:23 AM
I was told 14 of 16 valves were adjusted.
At 16k I think I'm going to go to the place that teaches you how to DIY.
02-07-2015, 12:23 PM
It's been my experience after owning several Honda's (VFR700, VFR800, ST1100, ST1300, another VFR800, etc.) with bucket/shim style valve trains that they rarely need to have a shim replaced. I check mine at 20K intervals usually and have only pulled a cam one time to replace a shim, and even then it really did not need a new shim as it was just at one end of the tolerance. My ST1100 has 78K on it when I sold it and the valves never went out of spec form mile 1K.
02-25-2015, 08:09 AM
I had my '13 checked at 16,000 mi this fall (Sept '14) and the dealer said that they were "right on".
« Next Oldest | Next Newest »
| Valve Adjustment Shims | dave | 13 | 678 |
07-28-2026, 12:49 PM Last Post: MagnaRider |
| Valve Adjustment and Camshaft Removal | dave | 5 | 618 |
03-21-2026, 04:49 PM Last Post: Cormanus |
First Check Engine Light Ever on a Bike | doug1976 | 2 | 227 |
01-14-2026, 06:47 PM Last Post: Cormanus |
| Valve Adjustment | dave | 6 | 854 |
08-29-2025, 10:46 AM Last Post: dave |
| Valve Cover Baffle lining ? | bflint | 6 | 922 |
07-26-2025, 11:27 AM Last Post: bflint |
| Check your clips! | Gone in 60 | 3 | 611 |
07-01-2025, 11:27 AM Last Post: Gone in 60 |
| Valve Adjustment Intervals | CBRider_imp | 32 | 2,819 |
04-21-2025, 02:24 PM Last Post: Jurlie_imp |
| Basic Maintenance: Daily Check | rdprdp01 | 17 | 1,369 |
03-01-2025, 02:52 AM Last Post: Gone in 60 |
| Time to check the air cleaner! | The A-man | 6 | 671 |
08-22-2024, 09:39 AM Last Post: the Ferret |
| Valve Adjustment Tolerances - How Far Do You Go? | dave | 14 | 1,478 |
10-18-2023, 09:28 PM Last Post: The Gecko_imp |
