torque spec question (2015 CB1100 DELUXE/ABS)
hello everyone!
I bought CB1100 DLX last week.
but it was japan ver. (they called 'CB1100EX special ver'.)
I read the owner manual.
but the japan manual did not have a torque spec.
does the torque spec of CB1100EX and CB1100 DLX are same?
(what I want to know is the front axle, brake caliper mount bolt, rear axle...)
[Image: 6b1241a11485e8200132405c593a0b8b.jpg]
I found the answer in this forum to myself.
follow this link : http://www.cb1100forum.com/forum/showthr...p?tid=2708
difference was rear axle torque value.
(2014 DLX - 65 FT LBS / 88Nm)
thank you Mr. ferret!
Sorry YHK I thought I had responded to this. I think the other specs are same as the 13 model and I can look them up for you if you still need them (front axle, brake calipe bolts )
(04-19-2015, 02:09 AM)The ferret_imp Wrote: Sorry YHK I thought I had responded to this. I think the other specs are same as the 13 model and I can look them up for you if you still need them (front axle, brake calipe bolts )
thanks to reply, Mr. ferret.
I want to know front axle, brake caliper and handlebar mount bolt(x4) torque value.
Thanks
Brake caliper bolts 23 ft lbs
Front axle bolt 44 ft lbs
Front axle pinch bolts 19 ft lbs
Handlebar clamp bolts 15 ft lbs
thanks again, Mr ferret! Thumbs Up
Welcome sir. Need any more, just ask.
Mr ferret,
I need your help!
I bought Over racing SS slip on exhaust.
but it necessary to replace the center stand mainshaft.
I want to know center stand mainshaft torque value.
and exhaust strap band bolt torque, fuel tank mount bolt torque value too.
I have the 2013 manual, but the specs should be the same for that info.
tank bolt. No spec listed. Manual says tighten bolt securely. If you are a torque fanatic, you would use the standard torque value listed for the bolt size. Need to know the size of the bolt.
Center stand bolt. Is Center Stand pivot pipe mounting bolt: 9 ft. lbs. Is an ALOC bolt, replace with new one.
Muffler band bolt: 15 ft. lbs
really appreciate for you!
I will do this job quickly Thumbs Up
  Torque value question Jonnyteabag_imp 9 632 03-10-2023, 01:00 AM
Last Post: 1973cb750
  2014 cb1100 Torque specs for two specific locations Dd808_imp 8 637 09-08-2021, 11:07 AM
Last Post: Dd808_imp
  2014 CB1100 Deluxe No front brakes Roger the shrubber_imp 16 997 08-05-2021, 02:01 AM
  Handlebar bolts torque value? (CB1100RS -18) Olof_imp 3 387 04-03-2021, 01:35 AM
  engine oil change time interval in kilometers CB1100 EX 2015 Alfgaxatico_imp 21 1,352 03-28-2021, 07:40 AM
Last Post: Speed_imp
  Valve Shimming - which side of spec? bflint 36 2,586 02-02-2021, 09:14 AM
   front suspension oil change CB1100 EX 2015 (23700 kms). recommendations ?. Alfgaxatico_imp 7 637 11-23-2020, 07:34 AM
Last Post: Alfgaxatico_imp
  Rust/corrosion - 2015 EX model N4RN_imp 7 649 10-26-2020, 08:25 PM
Last Post: syncronizator_imp
  Engine mount bolt torque value TCinNC_imp 43 2,489 07-31-2020, 05:00 PM
Last Post: treedoc_imp
  Shock bolt torque HBFL_imp 9 668 04-11-2019, 07:04 AM
