Idle screw?
The owner's manual says 1,000 plus or - 100 rpm. My Cb1100 is running a little too high. I know that motor must be warm. I think the screw can be seen from the right side of bike. Brake side. Am I right? If anyone knows, please let me know something. It has been a while since I had a in-line four! Thanks folks, God Bless...
Jayimpalaman
jcherry5858@gmail.com
[quote='Jayimpalaman' pid='3874' dateline='1370655623']
Jayimpalaman
The service manual says the idle speed must be checked when warm with a tach that will read a50rpm change accurately. Idle speed should be 1100 +-100 rpm.
If not correct, check throttle operation and freeplay
Intake air leak or engine top end problem
IACV operation
thats if no DTC and MIL blinking and some other system are good.
It says that The system eliminates the need for manual idle speed adjustment compared to previous designs.
Edit to add: I'm sure you understand this is a fuel injected computer controlled engine. There is no idle speed adjustment like on a carb'd engine.
(06-07-2013, 11:50 AM)Lord Popgun_imp Wrote: [quote='Jayimpalaman' pid='3874' dateline='1370655623']
Jayimpalaman
IACV operation
Efi engines can have an idle fuel adjustment. My cruiser is efi and has a warm idle adjustment set screw.
I didn't see one in the service manual procedures, but I'll look in more detail later.
(06-08-2013, 01:47 AM)Lord Popgun_imp Wrote: I didn't see one in the service manual procedures, but I'll look in more detail later.
I can't find one on this bike (and there's no mention in the Owner's Manual), but I've owned plenty of fuel-injected bikes that had idle adjustment knobs.
Ok, I learn something new every day no matter how hard I try not to Big Grin
I looked on the bike and I think the screw he is talking about is in the middle of the throttle body assm. It has a spring on it.
It is shown in the manual on page 5-52. There is no mention of adjusting it anywhere. In fact the manual says not to mess with any of the white painted screws, nuts or bolts or throttle valve synchronization may fail (The common systems manual says re-adjustment may not be possible).
That screw is visible from the right side of the bike looking up at the bottom of the body. Using an inspection mirror, mine has white paint on it.
I would guess it is used by the factory to set up the throttle sync. and I would suggest not messing with it.
Thanks Popgun, you could be so right. It warms up at 1500 rpm and then settles down after the motor is warm. I was just used to a Victory motor and they idle around 900 to 1,000 rpm. I just love my CB1100!!! Thanks again..... Jayimpalaman
Yeah, mine idles a little high when its cold. Heck, so does my car! The computer takes care of all that.
If you have any concerns though, I would suggest talking to the dealer as the bikes are under warrenty and you don't want to mess that up by screwing with the machine.
Yes, I could have been over excited to turn on a nut or something! I will adjust my handlebars (again) Thanks again Popgun. Jayimpalaman
Now faith is the substance of things hoped for , the evidence of things not seen. Heb. 11:1
Frustrated.. My 85' FUELIE Gold Wing had a SCREW for Idle Adjustment.. C'mon Riders.. Whassup with Closed Minds! Of course there'a an idle adjustment youngsters!.. Now. Where?
  CB1100 Idle speed instability problem ericlo69_imp 1,434 97,663 07-26-2026, 01:51 AM
  JIS screw drivers Ridem32_imp 26 1,375 06-12-2026, 06:56 PM
  idle problem update 1973cb750 37 1,421 05-12-2026, 08:38 PM
Last Post: rdprdp01
  Idle a little rough and miss fire when revved johnnyH_imp 3 359 09-15-2024, 12:16 AM
  Sight Glass Screw Mickey Dublin_imp 16 1,391 11-22-2023, 08:25 AM
  another idle thread Tom_imp 11 864 11-20-2023, 01:30 PM
  TPS Sourcing because of High Idle Obi-wan Kenobi_imp 38 2,362 09-14-2023, 10:08 PM
  Honda CB1100 Rough Idle Solution dickie1951_imp 56 3,800 09-06-2023, 01:36 AM
  High idle mattmcuomo@yahoo.com 7 581 10-29-2022, 11:09 AM
  Fast Idle Problem Solved Nachodaddy 17 1,319 10-08-2022, 09:18 AM
