Got my Drive Sprocket off
Pulled the Drive Sprocket off. See photos below for wear after 55000kms.
[Image: f56a02eb25046b50d64382541b4a4af6.jpg]
[Image: d1de815a16889a76a866017c8fb59a93.jpg]
[Image: 42b7dd5730f75b507860a28b3ef80235.jpg]
After giving it some thought, ably assisted by our forum members, I will go to Barry Francis, Australia for an OEM Drive Sprocket replacement at AUD80, no freight charge. The sprocket in the USA sells for approximately USD50 which equates roughly to AUD64 and commission plus freight ranging from USD8.95 for ground and USD27.95 for express.
Chain and Driven Sprocket yet to be removed.
Cheers and thanks to all.
Not bad for the mileage but in need of replacement. Does the driven sprocket show as much wear? Drive sprockets always wear faster it seems. Drive sprocket on my Tiger 1050 was toast at 12,000 miles.
Looks like you got every mile out of it. Kinda cool how Honda does the rubber insert. Probably to keep harmonics & vibrations down. Thanks for posting. I'm also curious to see the rear sprocket.
I will take the driven sprocket off tomorrow. Might get to the chain and chain slider as well.
Quote:..........lol Probably to keep harmonics & vibrations down. .......
Thats why I have decided to go OEM for the drive sprocket. I don't believe the JT has the rubber inserts.
Cheers again
  Chain and Sprocket Options? Yata-Garasu_imp 22 2,095 12-23-2024, 04:47 AM
  Chain or sprocket problem ? The Gecko_imp 14 1,288 07-30-2024, 10:05 AM
  Front sprocket bolt cant be moved misterprofessionality 55 4,616 03-13-2023, 12:18 PM
  Front drive chain sprocket wear 1970Cadillac_imp 15 1,261 11-29-2022, 07:49 AM
  17 tooth CS sprocket install, comments. Bike #12_imp 11 1,001 01-03-2022, 08:30 AM
  Another chain and sprocket question bflint 20 1,589 10-13-2020, 01:00 PM
Last Post: tod.branko_imp
  Alloy Sprocket woes Ninemeister_imp 22 1,768 09-24-2020, 09:23 AM
Last Post: Ninemeister_imp
  Broken rubber on front sprocket zirconxi_imp 7 563 05-24-2020, 11:17 AM
Last Post: zirconxi_imp
  Drive Chain upkeep LakeWylieJoe_imp 18 1,131 05-20-2020, 01:36 AM
  Checking Drive Chain Slack Townie_imp 26 1,823 01-15-2020, 11:14 PM
Last Post: cocojamboo_imp
