Allen Head Size for Rear Rack Install?
Hey, My new rack comes today. I just did some checking, the 6mm is to small, the 7mm to big. Are those rear allen heads 6.5mm or so? The ones that need to come off to install the rack.
I may have to do a tool run anyway later, just thought I would ask here before I ride to the tool shop and see what fits.
Since they may be tight, I may need a head that will attach to my socket wrench? Thanks.
The ones that come off are the bungie hook ones. They aren't 8mm? The new ones are according to the instructions (for a Honda rack).
I can't check right now as I am not at home. I will later if no one answers first.
If its the bungie hook ones 6mm allen fits mine
I just checked mine. Both the originals and the bolts included with the rack are 6mm.
Sure someone didn't mix up your metric and standard allens?
Like Ferret said, the bungie ones are the ones for a Honda rack install.
Thanks, yes, my Allen wrenches could be out of order, still I go from to small to larger than required. I have another set around I will look for. These are the factory Allen head bolts that come off to attach a rack.
Another update, the package today was my S.W. Motech 'crashbars'. I thought the rack was in the same package but no. This means I have more time to get the correct size Allen tool to remove the bolts.
The S.W. crashbars went on fine, subtle but quality looks excellent.
Item 11 is the bolt we are talking about. Wrong link, have to fix it.
OK, this link: http://www.partsfish.com/oemparts/a/hon/...d3256/seat
SUCCESS! My bad. Yes, my standards were to high. The 6mm left a bit of wobble, I had expected a tighter fit. My 6mm Allen wrench loosened them all up just fine, then I resnugged until my rack comes. Now I have no need to go on a tool hunt, good since I already have about 3 sets of Allen wrenches from buying them on the road.
Thanks for the assistance, 6mm is correct.
  Delkevic 9" Oval Install Problems. jbird06_imp 4 474 06-11-2024, 08:25 AM
Last Post: devildogdoc_imp
  What is the Correct Chain Size for a 2014 Model? chync_imp 12 1,164 02-28-2023, 01:16 AM
Last Post: Maturecheese_imp
  Install a 6-speed trans on a 2013? amacbeth_imp 37 3,307 02-21-2023, 12:22 PM
  Weight limit on genuine Honda rear rack DaveP_imp 14 1,247 11-17-2022, 02:57 AM
  Brake reservoir screw head issue satchit 72 5,406 04-24-2022, 11:55 PM
  Chrome cylinder head cap Juancho76_imp 21 1,699 04-03-2022, 08:48 AM
Last Post: Juancho76_imp
  17 tooth CS sprocket install, comments. Bike #12_imp 11 1,000 01-03-2022, 08:30 AM
  Tail light install problem iamheero_imp 9 731 11-27-2021, 02:58 AM
Last Post: Bazbro_imp
  2013 versus 2014 wheel size Houtman_imp 19 1,619 10-08-2021, 05:11 AM
  Cams, Compression, Head Work? boynton6spd_imp 12 981 08-08-2021, 02:27 AM
Last Post: old blue_imp
