Front rotor bolt torque?
Installing new magnesium wheels; anyone know what the rotor bolt torque spec happens to be? 6mm bolts, so I'm guessing in the 7Nm range?
Front Brake Disc Bolt--20Nm, or 15 ft. lbs for non metric types
Rear Brake Disc Bolt--42Nm or 31 ft. lbs
The manual says they are ALOC bolts, replace with new ones.
(05-08-2015, 09:10 AM)HaGut_imp Wrote: Installing new magnesium wheels; anyone know what the rotor bolt torque spec happens to be? 6mm bolts, so I'm guessing in the 7Nm range?
Thanks popgun!
(05-08-2015, 09:33 AM)Lord Popgun_imp Wrote: Front Brake Disc Bolt--20Nm, or 15 ft. lbs for non metric types
I thought the rotor bolts were reusable and but the caliper bolts needed replacement. Am I mistaken?
That's correct. Having said that I just removed my front calipers this morning and didn't renew the bolts on replacement. Sad
Just add thread locker and you will be fine.
ALOC= Add Locker Or Crash Smile Or more likely, anaerobic locking compound.
I put Loctite Medium on the threads. Thanks though.
  Front sprocket bolt cant be moved misterprofessionality 55 3,636 03-13-2023, 12:18 PM
  Torque value question Jonnyteabag_imp 9 520 03-10-2023, 01:00 AM
Last Post: 1973cb750
  2014 cb1100 Torque specs for two specific locations Dd808_imp 8 490 09-08-2021, 11:07 AM
Last Post: Dd808_imp
  Handlebar bolts torque value? (CB1100RS -18) Olof_imp 3 299 04-03-2021, 01:35 AM
  Rear brake rotor and new pads Sandhog_imp 13 720 01-08-2021, 04:51 AM
Last Post: ethan.phan613_imp
  Fork Tube hex head bolt tool fitment ? bflint 8 523 11-30-2020, 06:24 PM
Last Post: jtopiso_imp
  Engine mount bolt torque value TCinNC_imp 43 1,860 07-31-2020, 05:00 PM
Last Post: treedoc_imp
  possible bent rotor, new rotor sources? misterprofessionality 30 1,261 12-14-2019, 01:11 PM
Last Post: max
  Shock bolt torque HBFL_imp 9 513 04-11-2019, 07:04 AM
  torque specs? Flynbulldog_imp 30 1,537 03-09-2019, 01:13 AM
