pipe size?
Have an fugly sport bike muffler (Yoshimura) on my 13. What ID does a replacment muffler need to be be to fit over the end of the 4 into 1 collector?
50 views and nobody has a muffler they can measure the Id on the inlet side?
Sorry, I guess I didn't read the request close enough.
Using a micrometer, I read 1.667 inches. Hope that helps.
I forgot our bike is metric.
In MM it read 42.59 in one place, a little less in another.
And to add, the muffler has never been installed on a bike.
(06-19-2015, 09:55 AM)Lord Popgun_imp Wrote: Sorry, I guess I didn't read the request close enough.
Harley, Yamaha, Kawasaki, BMW use 1 7/8" ID mufflers. I was hoping that would be the measurement so I could use a generic muffler on my bike. The OD of the head pipe on most is 1 3/4". The muffler manufacturer will sometimes give you a shim to use the muffler on a 1 1/2" OD headpipe so one may work. Anyway, thanks! wg
Are you Wiredgeorge the Japanese carb guru from Mico?
(06-20-2015, 08:06 AM)Flynrider_imp Wrote: Are you Wiredgeorge the Japanese carb guru from Mico?
No, I am the Texan guru of vintage Japanese carb guru... Excited
ROFL I remember you from the KZ forum years ago. You're the last guy I would have expected to be riding a fuel injected bike Big Grin
ROFL
Any exhaust with a 1 3/4" ID will slide right in with 1 reducer ring. The ring ought to be roughly ~0.6-0.7mm thick. And most reducer rings on sale comes in a set of 3 and one of em will do the job for you. They retail typically around $7 - some exhausts will come with the reducer kit.
I just want to get rid of the Yoshimura slip on and put a stock looking muffler on. One from JC Whitney or JP Cycles (Universal type) as I think sport bike slip ons look a bit out of place. When I reach the magical number of posts I will likely put something in the classified for a trade with a local guy (San Antonio) area. There seems to be some sort of bracket needed with the Yosh slip on to retain the centerstand and I definitely want to retain the centerstand.
  Fork Pipe replacement suggestions danieljrmurray_imp 3 475 10-09-2023, 02:31 AM
Last Post: danieljrmurray_imp
  What is the Correct Chain Size for a 2014 Model? chync_imp 12 1,145 02-28-2023, 01:16 AM
Last Post: Maturecheese_imp
  2013 versus 2014 wheel size Houtman_imp 19 1,569 10-08-2021, 05:11 AM
  Pipe Master 4 into 4 Houtman_imp 127 8,440 07-24-2021, 06:39 AM
Last Post: michael1954
  Regina HPE chain-kit - looking forward to these coming in our size. Tev62 13 1,029 04-20-2021, 06:45 AM
  Oil Drain Plug Washer Size Tev62 14 1,021 11-18-2020, 06:29 PM
Last Post: jtopiso_imp
  Sprocket Size Retsel_imp 4 383 08-14-2017, 01:30 PM
Last Post: Retsel_imp
  Handlebar Clamp Bolt size? Nappi185_imp 7 655 08-08-2017, 01:49 PM
Last Post: Nappi185_imp
  Battery bolt size Sam Mac_imp 6 515 11-11-2016, 04:49 AM
Last Post: Randy B
  Tire Size Specs? 736cc_imp 9 533 11-10-2015, 09:12 AM
Last Post: Elipten_imp
