Size of Mufflers on DLX Model
Are the dual mufflers on the DLX the same size as the single muffler on the CB1100 Standard? Are they different in any way?
Gary
They are different. The diameter of the exit hole for the exaust gas is smaller (because it only has to handle gas volume from 2 cylinders) and the diameter of the muffler itself is smaller. If you need it, I can measure each and give you reasonably exact differences.
(08-06-2015, 01:59 PM)Redbird_imp Wrote: They are different. The diameter of the exit hole for the exaust gas is smaller (because it only has to handle gas volume from 2 cylinders) and the diameter of the muffler itself is smaller. If you need it, I can measure each and give you reasonably exact differences.
Redbird,
'Thanks' for the fast reply and the info. I got what I needed.
Gary
  Cam chain model and relpacement. syncronizator_imp 19 1,629 10-20-2023, 08:45 PM
  What is the Correct Chain Size for a 2014 Model? chync_imp 12 1,136 02-28-2023, 01:16 AM
Last Post: Maturecheese_imp
  2013 versus 2014 wheel size Houtman_imp 19 1,550 10-08-2021, 05:11 AM
  2010 model Power Commander alternative? 83NZA_imp 7 575 08-03-2021, 02:04 PM
Last Post: Aussieflyer
  Regina HPE chain-kit - looking forward to these coming in our size. Tev62 13 999 04-20-2021, 06:45 AM
  Parts interchangability on US model years '13/'14 vs. '17? Whoops 7 637 04-13-2021, 12:05 PM
  Oil Drain Plug Washer Size Tev62 14 1,008 11-18-2020, 06:29 PM
Last Post: jtopiso_imp
  Mandatory Tools for Road Trip (2017 model and later) 17-CB-002 35 2,595 10-29-2020, 12:03 PM
  Rust/corrosion - 2015 EX model N4RN_imp 7 651 10-26-2020, 08:25 PM
Last Post: syncronizator_imp
  Fuel tank interchangeability? Model difference questions.... 2014ltdltz 5 662 10-12-2020, 11:59 PM
Last Post: 2014ltdltz
