Reusing valve cover gasket.
Hello.
As the end of the season approaches I'm looking to do my valves before storage.
Can anyone who has done this before confirm wheather it's possible or not to reuse our valve cover gasket. Time for a new one at the dealer here is a while and I'd prefer not to buy it if it's not really necessary.
I would replace, its a rubber gasket but mine got stretched when I removed my valve cover.
you can get on ebay for $20, cheap insurance IMO
Certainly wouldnt hurt to have one on hand if you plan on keeping the bike a while.
Just out of curiosity...why would it be so critical to replace it?
If it doesn't seat properly...it leaks. Probably not much; and since it's out in the open, not leaking into an enclosed dry space...no biggie.
If it leaks after re-use, replacing it is relatively easy. Biggest hassle is cleaning up after the period of leaking.
(09-22-2015, 07:50 AM)JustPassinThru_imp Wrote: Just out of curiosity...why would it be so critical to replace it?
Yeah. This is my thinking as well.
I guess my only concern was that they are stuck on and have to be wrecked or it's a cheap POS (though not likely on a Honda) that breaks into three pieces from being heat hardened and then I'd be left with nothing till the dealer gets one in.
I'll probably just order one and wait. Canadian dealer price is ~$100.
Its $33.50 USD on this site: http://www.partsfish.com/oemparts/a/hon/...head-cover
  Valve Adjustment Shims dave 13 698 07-28-2026, 12:49 PM
Last Post: MagnaRider
  Valve Adjustment and Camshaft Removal dave 5 625 03-21-2026, 04:49 PM
  Knocking noises; vibrations in the handlebar; oil sipping at valve lid gasket TheLegend 47 5,667 11-16-2025, 12:01 PM
Last Post: TheLegend
  Valve Adjustment dave 6 861 08-29-2025, 10:46 AM
  Valve Cover Baffle lining ? bflint 6 934 07-26-2025, 11:27 AM
Last Post: bflint
  Valve Adjustment Intervals CBRider_imp 32 2,869 04-21-2025, 02:24 PM
Last Post: Jurlie_imp
  Left Side Crankcase Gasket Part number. jbird06_imp 1 322 03-26-2024, 08:56 AM
  Valve Adjustment Tolerances - How Far Do You Go? dave 14 1,484 10-18-2023, 09:28 PM
Last Post: The Gecko_imp
  Observed Valve Clearance Cormanus 16 1,439 03-06-2023, 09:03 AM
Last Post: Tejas_imp
  Arrow Slip on issue - stock gasket didn’t fit Ddawg1144_imp 4 466 02-21-2023, 07:51 AM
