Cam Chain Tensioner/Lift ?
Has anyone replaced the cam chain tensioner and lift? I have the valve cover off to check clearances and was wondering what else would have to come off to replace the tensioner stuff.
What do you mean "lift"? The tensioner is on the outside of the engine and there are 2 chain guides, one in front and one at the rear that is operated by the tensioner.
Parts list:
1. SPROCKET, CAM (46T)
14321-MGC-000
$94.39
Qty: 2
2. CHAIN, CAM (154L) (BORG WARNER)
14401-MAZ-003
$105.75
Qty: 1
3. LIFTER, TENSIONER
14500-MAZ-000
$98.49
Qty: 1
4. TENSIONER, CAM CHAIN
14511-MAZ-300
$29.12
Qty: 1
5. BASE, CAM CHAIN TENSIONER
14520-MAZ-000
$59.57
Qty: 1
6. GUIDE B, CAM CHAIN
14546-MGC-000
$51.78
Qty: 1
7. GASKET, TENSIONER LIFTER
14560-MY5-851
$5.07
Qty: 1
8. GUIDE A, CAM CHAIN
14620-MAZ-000
$60.71
Qty: 1
9. BOLT, FLANGE (6X10) (NSHF)
90004-GHB-600
$3.10
Qty: 1
10. BOLT, FLANGE (6X25) (NSHF)
90004-GHB-670
$2.95
Qty: 2
11. BOLT, FLANGE KNOCK (7X10.5) (Honda Code 1824291)
90082-HA0-000
$2.95
Qty: 4
12. WASHER, SEALING (6MM)
90442-397-000
$2.95
Qty: 1
13. BOLT, FLANGE (6X14) (Honda Code 2410884)
95701-06014-00
$2.95
Qty: 2
[Image: kEZTQ3T.png]
Posts: 2,500(0.57 per day | 0.79 percent of total posts)
Registration Date: 04-26-2013, 09:56 PM
not sure its really needed I've seen some 140k mile cb 1100s and only valve clearance checks and spark plugs
2014 Cb1100 STANDARD #2061  ECU flashing.    Biker        https://www.facebook.com/cj.h.pfeiffer
Based on the current answers, I assume nobody has replace the cam chain tensioner lifter before.
(07-08-2025, 08:49 PM)bflint Wrote: Based on the current answers, I assume nobody has replace the cam chain tensioner lifter before.
If it isn't broke, don't fix it.
Hey Dave ... the point is I don't know if its broke or not.  I just know I was hearing a loose tappet kinda of noise and the valve clearances are all perfect.  Also know that my previous 1991 Honda Nighthawk 750 needed a new cam chain tensioner at about 30k (in 2015) so that got me thinking about the possibility on my CB1100.   Replacing the tensioner lifter can be done anytime per my research, but the internal components (tensioner) require at least the valve cover to be off and maybe even the cams.
I don’t recall anybody ever having a problem with the tensioner lifter or having problems with it.
Holder of the CB1100forum Secret Decoder Ring
2012 ST1300
2013 CB1100
I find your lack of RLETs disturbing
  I've already put my CB1100 up on the lift Guth_imp 21 1,545 12-09-2021, 01:18 AM
Last Post: Raceman_imp
  What ‘Bike Lift’ do you recommend? ride4now_imp 17 1,086 01-11-2021, 02:05 AM
Last Post: j3gq_imp
  Chain Tensioner Adjustment - How To ?? markT_imp 20 1,379 10-16-2018, 08:56 PM
  CB1100 assymetrical cam timing, lift, and duration. Roger the shrubber_imp 23 1,264 02-18-2018, 10:29 PM
Last Post: jimgl3_imp
  Harbor Freight Motorcycle Lift Frulk_imp 10 747 03-15-2016, 04:30 AM
Last Post: AzBob_imp
  Work Lift Question Ron in MO_imp 17 1,025 12-17-2015, 03:22 AM
Last Post: redbirds_imp
  Anyone know of a front head lift stand compatible with the CB1100? chync_imp 5 462 10-23-2015, 08:31 AM
Last Post: kennyw
